Hi, Just finished building a jet boat from nothing, though I would post it here as it was very hard for me to find info to build it. It was a fun project, and turned out to be a fun boat as well.
Here's a video of the finished boat, and the info on how I got there is below!
Here's the parts and materials I started with.
I cured a flat sheet of fiberglass 2 plys thick. Then while this was curing I used thick cardboard like paper to make templates for all my hull pieces. Once the fiberglass cured, I traced the pieces and cut them out. Tomorrow I will make a temp frame that will only be there to hold the parts in place while they cure together then I will bond all my parts together with fiberglass. This way I should be able to build the hull without a mold. Here is a picture of my parts, and some extra fiberglass sheet I bonded. The 16oz water bottle is in the pic for a size reference.
Well I made the basic jet drive that I plan on using, and started glassing the hull together. Here's some pictures of the hull.
Now for the Jet drive. I decided since this is small and does not pack too much power I can hopefully get away with a combo of wood, resin and fiberglass. So I quickly made what will be my drive housing and impeller from wood. They still need a bunch of fine touches that I will do my hand to smooth and finish them. I am trying to use a screw type design for my impeller. I have no clue how it will work, but why not... The impeller is 1/2" diameter by 3/4" length. My shaft is 1/8 helicopter shaft. Once finished the inside of the housing and impeller will be sealed with fiberglass resin to waterproof. I will make a fiberglass grate, nozzle, stator, and a duct to fit over it that will be used for steering. The housing will have an aluminum stuffing tube, which I had that perfectly fits my shaft. It was going to be my new tail shaft for the helicopter. If this impeller does not work well I will make another differently and try that out... The housing will also be trimmed down considerably. Well here's the pics:
This is my radio, reciever/esc, steering servo, motor, jet drive. Tiny!
