HJ's First Twin Cat Build ''CF Daytona''
  • HYDROJERRY
    • Jan 2010
    • 2503
    #46
    Got my flex shafts .187x3/16,, but dumb me i got two of the same and foregot one needs to be right hand so i gess ones going up for sale!!! But i can still use it for placement!!!
    Question,,with using .187 with no teflon i have 2 choices on wich size tube to use,, first pic shows with the 7/32 tube fits perfect but will have slight drag when i bend it!!! Second pic is with the 1/4 tubing,,, has some slop but should not have any drag at all after i bend it SO wich one should i use??????
    • Rumdog
      • 6453
      #47
      Use the 1/4" Tube!
      • HYDROJERRY
        • Jan 2010
        • 2503
        #48
        ok,, i gess the little slop is ok then.. what about aluminum tubing,,, i like how it bends easyer and looks silver but i gess the brass is ok if thats what i need to use..
        • monojeff
          Moderator
          • Nov 2010
          • 2547
          #49
          Originally posted by HYDROJERRY
          ok,, i gess the little slop is ok then.. what about aluminum tubing,,, i like how it bends easier and looks silver but i guess the brass is ok if thats what i need to use..
          You could always get a size up for the aluminum and put it over the brass just for the look of it.
          I like the idea of using the brass for the bolts as a support.
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
          • HYDROJERRY
            • Jan 2010
            • 2503
            #50
            Thanks Jeff,, but im not so sure i want to waste an extra tube per side but it is an idea,,,
            the tube over the bolts are so when you tighten the bolts you actualy squeezing against the tube and not the hull,,but you probly no that!!!
            • HYDROJERRY
              • Jan 2010
              • 2503
              #51
              So i moved on for now,,, i filled the rudder extension in the hull with 1min epoxy mainly cuz the tube is like a big suringe with the long tip let it dry a few hours and installed my rudder,, for those who dont no i took a rudder/strut system like the on that comes on the Genesis and i removed the strut part and cut the rudder bracket short,,i think it will work ok.. I also orderd the 90* etti nipples for my motor mounts so gotta wait again till they come in...
              • MadChad
                • Mar 2010
                • 17
                #52
                Looking good HJ! cant wait to see some videos but take your time and do it right.
                • HYDROJERRY
                  • Jan 2010
                  • 2503
                  #53
                  hay MD glad to see you on ose bro,, yeah im trying to do it wright and as my first time doing a twin its taking me longer than i thought it would!!! every time i think im getting somewhere i find i need something else but i gess thats how it goes,,
                  • battlefury
                    • Sep 2010
                    • 256
                    #54
                    yes, it was a drag when i was in the process of building it. Everything thing was double the effort. Double the soldering job. Double the drilling, Double the fitting. You are looking good HJ keep it there, you will find it worth a damn in the end! have fun
                    http://www.youtube.com/user/f4agusta09?feature=mhee
                    • HYDROJERRY
                      • Jan 2010
                      • 2503
                      #55
                      thanks bro did you ever do a vid of yours,, id love to see one running!!!
                      • HYDROJERRY
                        • Jan 2010
                        • 2503
                        #56
                        Got the nipples for the water cooled motor mounts saturday,, they are the ones from ETTI 4mm with no threads so how can i glue them in so i can get moving on,,on this build..
                        • battlefury
                          • Sep 2010
                          • 256
                          #57
                          I gotten the ones with thread so i locklite it. its strong enough for me. Be sure not to have the holes plugged
                          • HYDROJERRY
                            • Jan 2010
                            • 2503
                            #58
                            the only ones i saw with 4mm threads was a nut looking style, the ones i got the head part is round and the nipple to go in the motor mount is super short with no threads,, maybe i need to order the other ones, but that would suck,,, it would be the 3rd pair ive orderd trying to get 90* nipples on these things..
                            • battlefury
                              • Sep 2010
                              • 256
                              #59
                              i would have send you my nipples if i only knew later they will be redundant. however, they super locklite to my mounts now.
                              if you plan on running inrunners these 90 nipples will only hinder your way. On the contrary with outrunners you would be needing them.
                              • CHUD
                                • 497
                                #60
                                Hay bro did ya get that other flex saft yet,I want to see this baby in the water,
