1/6 Crackerbox getting dialed in
I have been building several 1/6 Crackerboxes. The 1/6 Crackerbox has a temendous performance advantage above the old 1/10 scale size right from the start. Along the way I have been making some small changes to the hulls and drivelines to see what effect these changes have on the performance and handeling characteristics of a 1/6 Cracker. I built this hull 31.5 inches long with a full 5 degrees deadrise per side for a total of 10 degrees deadrise. The stuffing tube has a very slight J bend which allows the prop to have a little less downward angle but is still under the transome. I placed the trim tabs further apart from each other. Once the hull was ready for paint ,I painted her the same as my last one as I really like that paint job and thought It was only right to name her Hot Stuff II. Next when building the cockpit and drivers I set the driver and mechanic lower in to the hatch to create a littlle less drag. The end result of the changes I made created a great running Crackerbox. Its not a night and day difference but this set up seems a bit more predictable and and holds water a bit more. If you have never diven a Crackerbox they can be a handful to drive and can be very frustrating. This set up lessens those habbits. Here are a few pics of her!
Tags: None -
Few more pics
Here are a few more shots of the driveline and internal buisness end.
Thanks for the comments guys, I don't have or use plans. I designed them around APBA rules scaled to 1/6 size then made templates using demensions and line drawings. Kind of trial and error until I was happy with the end results. I'm not a good enough draftsman to create a set of plans that are good enough for someone else to use or follow.
If your boat or any boat has 5 deg of deadrise each side then it has 5deg deadrise total you dont add the two together .The deadrise is the angle measured upwards from keel level,you dont say i have 5one side 5 the other therefore i have 10deg deadrise.So your cracker has 5 deg of deadrise
Oh Thanks!!If your boat or any boat has 5 deg of deadrise each side then it has 5deg deadrise total you dont add the two together .The deadrise is the angle measured upwards from keel level,you dont say i have 5one side 5 the other therefore i have 10deg deadrise.So your cracker has 5 deg of deadrise
http://www.answers.com/topic/deadriseComment
Not of this one yet, but here is a video of one of the earlier builds.
We dont see many of these over this side of the pond but i have to say i love the look of them and they seem like fun too.Keep up the good work you build some nice looking boats
Thanks for the comments. Crackerboxes are pretty neat, what they lack in fast, they make up for in fun!
Might need to build me one they do look like a lot of fun.Do you know of any plans available for something this size.
MartComment
I like it, might be my next one, plans
