I have the drives and rudder mounted,, the rudder is reinforced on the inside of the hull. I fitted and mounted the motor mounts and stuffing boxes, the motor mounts took quit a bit of time to fit them to the contours of the inside of the hull .I was not look foward to building this boat but once I got started I am very EXCITED Chris
MHZ Mystic build for Joseph Y
Chris, did you do the CF work? -
Yes sir...very cool looking!! Bullet proof even!!!
-KentComment
What exactly do you guys use to attach things like the motor mounts to the hull? I'm assuming epoxy, but please be specific.
This should be a nice build! Are you fitting a power system or just getting it ready for his motors/escs of choice? I'm curious what's going to push this hull, which is very nice by the way!I have the drives and rudder mounted,, the rudder is reinforced on the inside of the hull. I fitted and mounted the motor mounts and stuffing boxes, the motor mounts took quit a bit of time to fit them to the contours of the inside of the hull .I was not look foward to building this boat but once I got started I am very EXCITED Chris
When I do the motor mounts in my boats I usually make them out of carboard first, that cuts down on a lot of the time spent fitting them. Being the experienced build you are, I'm guessing you already do this in some form, but I thought I would throw it out there just in case its something you have yet to try.Comment
Yes I did make templets out of cardboard but I ended up moving the motors so it needed some fine tweeking I am installing 4074 2000 KV with HK 180 ESC I was going to build the boat for myself but I changed my mind thanks for the nice comments guys !!! ChrisThis should be a nice build! Are you fitting a power system or just getting it ready for his motors/escs of choice? I'm curious what's going to push this hull, which is very nice by the way!
I have gotten some more done
I mounted the C/F stuffing box supports installed 1/8" ID Twinn water pickups installed 8/32 SS blind nuts for the cowl have the esc trays done Check it out and LMK how you like it thanks chrisComment
and some more pics
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Comment
Always looks so easy when i see everyone else doing it but,,eek
Everytime i look at mine im still building i just worry!!
