Delta Force Vortex 24
  • sampit
    • Jul 2009
    • 447
    Hi Vortex 22" fans
    can I ask some advise for a motor for the Vortex Hydro 22"
    I have the boat built but just need to decide on the motor
    I would like to run on 1 x 3s 4500Mah Turnigy Nano lipo
    I have two spare motors to use and not sure what one would be the quickest
    any advise appreciated and idea of speed and prop size?
    ETTI 150A ESC
    bellow are the motors I have and the specs
    Leopard 4 pole 2860 3400KV brushless motor 3 turn D wind
    Specification:
    Max voltage: 17V
    Max Amp:80A
    Max power: 1300W
    RPM: 3400KV/volt
    Resistance: 0.0098
    Non-load current(7.4V): 2.5A
    Diameter: 28mm
    Length(excluded shaft): 64mm
    Weight: 176 gm
    Turnigy 36/56Kv: 2600rpm/v
    Power: 475W
    Turns: 4
    Resistance: 10
    Idle Current: 5.3
    Esc: 60
    Battery Config: 3-5S
    Length: 57mm
    Width: 36mm
    Shaft: 5mm
    Weight: 260g
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
    • lipdaddy
      • Feb 2010
      • 48
      I would go with the Turnigy 36/56 2600kv on 3s. It would be a similiar set up to what I'm running in the 24". It will be a rockett in a 22" hull.
      As for a prop. I just ran mine today with a Grim 38X55L and I liked it better than my X440. You should have no problem swinging either one and would be a good start.
      I keep telling myself I'm going to throw in a Feigao 8XL and 4S, but I have a hard time changing out a good set up that works really well. Who knows, maybe one day.
      Ryan
      • brazildesigns
        • 57
        Im not sure about te 1 3s. I had that on a Pica 22" plastic hull running a 2881kv motor and Kept puffing batts. I agree with lipdaddy and would suggest using the set-up calulator at OSE, You can play with the numbers with your setups and get the best prop/power setup and get an approximate speed with a 640 prop 3s 2p 2 160 amps. I found this after my 22' DF was setup and with my Eagle Tree E-Logger confirmed what the calulator figured, 50MPH. Changing the pitch obviously will effect the RPM and the load on your system. I want to see if I can back off on the pitch and raise the RPM while lightening the load will I get the same speed, That Calculator will tell me.
        Brian
        • newbie78
          • Sep 2009
          • 12
          Really nice! What kind of hardware (rudder etc.) are you running?
          • lipdaddy
            • Feb 2010
            • 48
            All the hardware was bought from OSE. Speedmaster .21 flat bottom strut, ose-80052 rudder, proboat hydro turn fin. I'm now running a 8 XL on 4S, 120 swordfish esc and a grim 38x63L prop. This boat is a rocket and probably my favorite.
            Ryan
            • newbie78
              • Sep 2009
              • 12
              Perfect Ryan. Many thanks!
              I have some left-overs from my SV27 project, so I could "recycle" some parts.
              • MadChad
                • Mar 2010
                • 17
                Speedmaster. I think it might be a ministrut.
                • lipdaddy
                  • Feb 2010
                  • 48
                  This is the strut I'm using.
                  http://www.offshoreelectrics.com/pro...d=ros-21-strut
                  Ryan
