1/10 Scratch Built Thunderboat (Finlay Plans)
  • monojeff
    Moderator
    • Nov 2010
    • 2562
    I started to assemble my 1/10 scale thunder boat a few days ago.
    This is my first thunderboat build & my second scratch build I have done.
    It will be in the theme of 68 U-1 Miss Budweiser when completed.
    Plans were scaled to be 96% so it was within legal scale size.
    The transom is 1/8" ply & all other frames are 1/8" light ply.
    Everything was rough cut on a band saw then sanded smooth.
    Tunnel floor is 1/32 birch ply which was cut with a box knife & straight edge.
    While laying the frames out I thought I had something messed up because of the gap where bulkhead C is.
    After closer look at the plans I realized there is suppose to be a brace there which goes under the bulkhead & over the tunnel break as a support.
    Everything is tacked in place with medium CA glue other then the tunnel brace which I epoxied the bottom of.
    The rear stringers are just sitting there holding bulkhead D level while the glue sets they will be permanently attached once the decking begins.
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7116
    those Finlay plans rule!! that's how I got my teeth wet, building one of his hydros from his plans and then getting advice directly from him (he is pretty present over on the red board).
    "Look good doin' it"
    See the fleet
    • monojeff
      Moderator
      • Nov 2010
      • 2562
      I plan to enter this is the build contest over there.
      Guys like Gary are what helps make this hobby grow & be a pleasure to be a part of!
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
      • monojeff
        Moderator
        • Nov 2010
        • 2562
        Deck striped are laid out & tacked down.
        For some reason when I measured the width of the stripes on my scaled down planes I thought I had got the correct width to fit but turns out was a little to narrow so luckily I had some 1/8" square stripes that fit perfectly in the void. So I used a combination of 1/8"x5/16" stripes & the 1/8"x1/8" stripes.
        I also tacked down the sponson brace which I used is 1/8"x 5/16" basswood sticks cut to size.
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • Hydromaniac
          • Oct 2007
          • 816
          Gary's plans build a great running boat. Another 1/10 scaler , sweet. Looks good . Can't wait to see her finished!!
          www.rockymountainthunderboats.org
          • monojeff
            Moderator
            • Nov 2010
            • 2562
            So I have heard.
            Appreciate it, hope I can do the plans justice & make this boat look & run as good as I hope it will!
            OSE GIFTING ELF
            HAPPY HOLIDAYS!!
            • monojeff
              Moderator
              • Nov 2010
              • 2562
              I had to remove the build from the jig so I could sand down the stringers a little to help the non trips line up correctly.
              Soon as I sanded them down I put it back on the jig to tack on the non trips which were also cut from 1/32 birch ply.
              Soon as the CA was dry on the non trips I started to epoxy all the the joints.
              All of the 90 degrees I added 1/4" balsa triangle to stiffen things up.
              The non trips are going to need to be sanded down before decking so everything will be even with the bulkheads.
              OSE GIFTING ELF
              HAPPY HOLIDAYS!!
              • monojeff
                Moderator
                • Nov 2010
                • 2562
                Started on the sponson bottoms today.
                Tapered the edges so everything would be nice & flush once glued together.
                I used tape to keep the edges nice & tight then flipped it over & laid down the epoxy.
                OSE GIFTING ELF
                HAPPY HOLIDAYS!!
                • monojeff
                  Moderator
                  • Nov 2010
                  • 2562
                  Took the tape off the bottom skins of the sponsons & everything looks pretty good.
                  I probably should have cut the tunnel edge over sized so I could sand it smooth.
                  Nothing a little mixture of cab-o-sil & micro balloons can't fix.
                  Worked on the sponson sides this morning.
                  Beveled the bottom edge & overlapped the bottom edge so I can sand it smooth once epoxy sets.
                  OSE GIFTING ELF
                  HAPPY HOLIDAYS!!
                  • monojeff
                    Moderator
                    • Nov 2010
                    • 2562
                    Here are some more pics with all the tape off.
                    Next step is to sand & smooth everything I have done up to this point.
                    OSE GIFTING ELF
                    HAPPY HOLIDAYS!!
                    • JimClark
                      • 5907
                      Looking great Jeff
                      Billy Graham
                      • monojeff
                        Moderator
                        • Nov 2010
                        • 2562
                        Originally posted by JimClark
                        Looking great Jeff
                        Thanks Jim appreciate all your help!
                        I do have another question for you.
                        On the back of the sponsons where the side meets the deck I have noticed there is suppose to be an overhang.
                        I am not sure how far it should overhang?
                        Also should it be flush on the bottom?
                        OSE GIFTING ELF
                        HAPPY HOLIDAYS!!
                        • JimClark
                          • 5907
                          I will measure mine and get back to you shortly
                          Billy Graham
                          • JimClark
                            • 5907
                            I have two boats sitting in my garage one is scratchbuilt off Newton plans and one is a Carbonfiber hull . the carbon fiber hull is 5/16 inch at the deck and flush at the sponson and the scratch built is 3/8th at the deck and flush with the sponson.
                            Billy Graham
                            • monojeff
                              Moderator
                              • Nov 2010
                              • 2562
                              Thanks Jim!
                              OSE GIFTING ELF
                              HAPPY HOLIDAYS!!
