I thought I'd share this with you guys....with a lilttle bit of time on my hand Here is my new 30 inch BJ New Cowling, Trim Tabs, Color, Just waiting for my 110hv to come back from Castle...I'm gonna try it with a Feigao 9L with 6s 4500 and a 645 and see what gives.....
Drum Roll Please It's the BJ II
Looks good.
nice.
Now on to you setup.
did i read that right ? 9L on 6S with a 645?
that is the recipe for a charr'd boat for sure
a 9L would run from 2-4S on MAX a 637 prop or a 640 is you have a very loose running boat
6S on that motor would pooch it for sure, and a 645 would pooch it even faster.
Personally i would run 6S on a 12-14 XL can with a 437 to start then go up.
Or you could run the 9L on a 4S setup with a 432 prop to start. -
I ran the stock on 6s, I was thinking really on 12XL on 10s...I have a 632 But it's a 1/8th hubSamuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
Why most people run the 4 series octura and not the 6?Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
I only have 5's and 6's in lipo's iand in nimhs I have 9 and 10 cell pairs...The BJ can handle it, I've done 51 plus already on a 6's with the tabs I think I can keep the hull in water...Just a lil fun R&D while I decide on my next hull which is either a hpr 115 or a christo time to move up I like those Big hullsLast edited by RCprince; 12-09-2007, 04:48 AM.Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
I think what jeepers is getting at is that the lower voltage set up with the right prop has the potential to be faster because of the weight. I need to get mine back in the water with the gps to see if I can prove my point...lol...with the 6s set up, I'd start with an x438 and do an out and back pass then check the heat to try and avoid having to send your esc "back" in for repairs.
Good luck
TreyComment
Why most people recommend the 4 series props and not the 6 series propsSamuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
who is "most people"?
a prop is a prop, people recommenced props suited to a boat.Comment
What I meant is oft times you'd get a 4 series rec over a 6 series like 4 to 1...Just wondered why....I would think since the 6 series has a smaller diameter it would have a less paddle effect plus more pitch....which is or are the Ideal prop series for cats...do you want the stern to lift out the water or the bow?Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
the 6 series props can have what ever diameter you would like, Not alwayse a Smaller diameter, Paddle effect ? I don't know what you mean by that.
Yes the 6 series has more pitch then the 4 series counter part, it will run your boat more aggressive so it is possible to raise temps and amps. possibly why people recommend other wise ?
X series props are not lifting props
and for cats having the bow lift or drop is your choice. what ever works with your boat. There are to many to give you a straight up answer. Thats like saying " what has more horse power a GMC or ford. well lets see, there is over 60 models present and past."
you must be more specific. " what has more Hp a GMC Sonoma or a ford rangerComment
Looks good.
nice.
DouggieComment
my bj with the ammo 2300 and trinity 4200 6 cell packs has run a best of 44.7 running a M440 prop. I have tried a few different props so far, and this one has been the best. I need to work on my 642 a bit more to see what it will do.Comment
Final Mods....
This is the final hull mod...Still waiting for my 110 hv from castle....hopefully by christmas eve. I'm gonna run a feigao 9l and 5's 4500 with a 637...here are the picsSamuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
