Well since no one else has tried putting more power into it
currently using a castle cm26 6800kv motor and a jacket with a castle mamaba micro pro esc with a cooling plate thermal epoxied to the same fets that the stock heat sink was on. Bored the pick-up out to 1/8" and use 7/32" tubing, thru-hull hole needs enlarged slightly. Runs cold so far
I would recommend that any one that tries to replace the stock motor just get a new hull and drive. Trying to remove the unit from the silicone that they have it glued in with was rather destructive
What I've been using for a seal is standard gasket paper, cut it to fit and it seals excellently
currently playing with weight to try and get it to plane
