Super Sport 45
  • ksm2001
    • Jun 2007
    • 377
    Super Sport 45
    Just started my SS45 after having it boxed away for over a year.
    The set up will be:
    Neu 1527 1.5D
    Speedmaster hardware
    Peter Zicha motor mount
    Virginia Craftsman turn fin
    I'll be setting it up for 6s2p, still waiting for the new Castle Hydra Ice240
    I'll be building some side rails that will be epoxied inside the side walls to bolt the motor mount to.
    I'm not quite sure how I'm going to make the battery hold down so any suggestions would be appreciated. I'm thinking towards a pair of 5000 mAh positioned up front.
    Ken
    Here are a few pictures of what I've done so far.
    DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
  • Make-a-Wake
    FE Rules!
    • 5554
    Nice Build!!!
    • TotalPackage
      Banned
      • 601
      Sure is. Man its gonna turn out clean.Didnt want to offset your drive line?No rubber iso's on the mount?
      • ksm2001
        • Jun 2007
        • 377
        Thanks Guys for your encouraging comments.
        The strut is centered as per instructions from Phil. The turn fin and the offset of the ride pads I think create the offset needed but being this is my first hydro I'm not an expert, here is a picture of the ride pads which better explain my thinking. Isolators aren't needed in brushless systems as long as your motor and drive line are balanced properly.
        Ken
          • 7990
          Some hydros do run well with a centered driveline, my FE-30 mis one. Doesn't need left rudder trim. Never use "rubber isos" when mounting an FE motor, those are gas/nitro parts which only promote misalignment of the motor and stuffing tube. If your motor vibrates enough to need isolation - bin it.
          • bedrock
            • Aug 2009
            • 248
            Great Build!!
            Top Boat
            Be carfull with the Castle Hydra 240's - I had 1 brand new one go BANG 2 days ago in my 8th Scale Budweiser - have 2 more brand new will not be running with my current setup
            2215 1.5y 10S - - - 57mm prop
            Good luck.....
            Bedrock
            • ksm2001
              • Jun 2007
              • 377
              Thanks Bedrock and Jay for your comments
              I'm waiting for the new Ice Hydra 240, I was keeping an eye on the postings about the Ice 200 non hydra version and it looks like many people including Jay have had great results and reviews, so hope the Hydra version will be the same.
              • ksm2001
                • Jun 2007
                • 377
                An update to my build.
                I made the motor mount rails and rail covers removable so the boat is fully accessible for adding flotation and in the case of a mishap can be easier to repair if something happens to a sponson.
                My next part will be to cut an inch off the back canopy and epoxy it to the hull for easier taping. I'll also add hatch locks on the back and then prep the fiberglass filling in the holes, then it's off to the body shop for paint.
                Ken
                • Punisher 67
                  Ignore list member #67
                  • May 2008
                  • 1481
                  Looking real good my friend......... , I guess I better get off my duff and get that coupler machined .
                  Necessity is the mother of invention.............
                  Youtube Video's http://www.youtube.com/user/Titanis2000
                  • ksm2001
                    • Jun 2007
                    • 377
                    Thanks Peter for the comment, it will still be a while before its ready to run so no rush .
                    So others know what Peter and I are talking about, the coupler in the picture has 2 sets of 2 set screws that hold it onto the motor shaft, when I use a thrust bearing on the Neu 1527 as in the photo only the one set closest to the bearing are contacting the motor shaft. So what I need is a coupler with 3 set screws at 120 degrees apart in the same place as the ones closest to the bearing.
                      • 9479
                      Sweet looking build bro!
                      I need to get mine finished, but I need me a motor mount.....
                      • LuckyDuc
                        Team Ducati Racing
                        • Dec 2008
                        • 989
                        Nice build. If I was going to build a Q Sport Hydro this would be the hull I would go with too. I run this hull in the nitro Sport 40 class and love it.
                        Are you building this for sport running or heat racing?
                        • ksm2001
                          • Jun 2007
                          • 377
                          Thanks for your comments Guys.
                          Sean, I'm building it for sport running since we go out to the pond with the guys to rip around and everyone has something different to run. And I think Peters Sniper would swamp it
                          I first saw this boat a few years ago on Raydee's You Tube video and loved the way it ran, so it's been one that I've always wanted to build and and run.
                          Ken
                          • Gary
                            • Jan 2009
                            • 1104
                            I did the same thing. Saw Raydees boat and decided to build one. Mine loaded comes in around 12.5 lbs unfortunatly but has a consistent top speed of 87-89mph on 18.5 volts and a best top speed as of today of 73 mph on 14.8 batteries. Very stable hull when its dialed in and took me a year to get there but well worth it.
                            H&M 1/8 Miss Bud 73 mph
                            Chris Craft 16 mph
                            • Boaterguy
                              • 1760
                              Nice! Looks great!
