Hey Mart, with FE we really don't need to toss the Hydro in the water with the prop spinning.. I agree about getting the strut back where it was and try again...
50" Hydro Build
.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s -
If the boats bogging down on takeoff it sureley cant be good for the motor,give it a toss with a few rpm and it will takeoff which i would think will be easier on the motors and the whole setup.This is a large heavy boat so my way of doing it would be the same as with a gas hydro, give it some revs and toss it in with forward momentum.
MartComment
I'm not getting in to this onebut it helps to do some little turns to get it up on step. it helps brake the water off the boat. you have a high speed prop made for high speed at low speed they do not work well. this is not a small FE boat that is 2 lbs
hope it helps the little turn thing works good look at your vid and see where you get up on step in the turn it's a old trick hope it helps
RickComment
Mart
I've seen many nitros never get on pipe and just push the hull rather than fly across the water and just bog the motor
biggest reason I wont go nitro
with these FE's they have full power at take off
in other words the brushless motor really wont bog.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
another way is just to pin the throttle right off the start and hold on!
most nitros need to be thrown in or they dieLast edited by Brushless55; 03-26-2011, 08:23 PM..NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Hmmmmmm, a good bit of discussion since i was last on. I would prefer not to have to toss this behemoth into the lake and gun it simultaniously..........takes two that way, looks pretty lame i would imagine, and the tosser would most likely be my vid man, and i gotta have him ready!
I did see how it "got up" as i turned, i guess that works, and i also have not tried the ol' gun it from the get go...........i bet that would work. Gonna run tomorrow, i havent decided whether to run it with the strut down where it is with the prather to see if it gets the butt up, or move the strut back up and try the 6516 again..........i may try both in 2-3 minute runs each.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Carl, I would try the strut where you had it before the prop swap and punch it!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
I used to toss my old hydro in myself with a few revs,it gets quite easy once youve done it a few times lol.Also dont slow down in the corners too much these things are designed to run flat out in the turns,squeeky bum time hehe.
As for strut height id try it back where it was with this new prop and see what happens before changing anything else.We dont allways have to agree and im not saying im right its just an opinion based on what i found worked with the gas hydro.I know FE is different but the boats are the same and these things take some getting on plane i was just trying to help you get there easier,in the end you will do what you think is right all im saying is try it and see and then decide.Good luck with it.
MartComment
Mart.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
