Waverider Navaho build (large Apache style build)
  • martno1fan
    Banned
    • Jan 2011
    • 238
    #151
    Cmon Pate wheres the video .
    Thats a big speed difference wonder if its the motors or the esc,s lol.
    Mart
    • FastVee
      • Aug 2008
      • 649
      #152
      I do have some video, bbut not fast internet where I´m now. Maybe tomorrow, monday at the latest.
      Cant be sure if the gps is correct, need to do another run today.
      The esc´s are the same so most likely the motors are the reason for possible speed increase
      www.youtube.com/rangerpate
      • FastVee
        • Aug 2008
        • 649
        #153
        Tried the propshop props and the limit for the escs is reached.bit high temps but 75kph was reached.
        back to the plastic props for now. video later today.
        motors were also hot,could only hold my finger 2-3 sec. until i smelled bacon... -this was after 2 minute run.Batteries were also pretty warm.
        • FastVee
          • Aug 2008
          • 649
          #154
          Video here -> http://forums.offshoreelectrics.com/...222#post343222
          • martno1fan
            Banned
            • Jan 2011
            • 238
            #155
            awesome!!!
            • FastVee
              • Aug 2008
              • 649
              #156
              Lol, thanks m8.
              I hope I can afford better esc´s next summer, thinking 10-11s lipos... should go decent speed then.
              But the strut angle is still a bit low, should go over 80kph with simple adjustment of the struts.
              It really handles great, turns at wot are easy and no fear of flipping it.
              • martno1fan
                Banned
                • Jan 2011
                • 238
                #157
                She seems balanced perfect m8,i know how well these run when setup right and your def on the money so far.10 s lipo she would def be the fastest so far with that setup ,fastest so far with gas power is 59.5 or 6 lol.I think 10s would be well over that but im no expert on electric.Keep up the good work im enjoying your videos thanks for sharing.
                Mart
                • Earthquakeboy
                  • Nov 2010
                  • 20
                  #158
                  Hi, I'm a newby that's one cool apache your boat rocks!!! I've got an apache 57 hull which I bought off and I'm installing twin kb45 8xl 1600kv motors but seeing your boat Fly, I should have purchased the same motors which you have. Any tips on choosing props for the twin kb's?? I've also got twin SS 200a boat esc and twin 6s 8000mah lipos from hobbyking as well.
                  Cheers & Happy Boating
                  • FastVee
                    • Aug 2008
                    • 649
                    #159
                    Hi, and thanks!
                    Honestly, ...I´m sorry but the 1600kv is way too much for this sized boat. -if you must try it, start with ~45mm props (and that could be too smal to get blades wet and moving the boat at all). -30sec test first, if everything is ok, then 1 minute and so on.
                    Do you have plans of watercooling the motors? -I use outrunners and they are air cooled but kb.s are inrunners and could need extra cooling.
                    I have the ss air esc´s atm, they are the same as boat series, but different software(more timing).
                    For sport running at around 40mph using 57mm props the electrics did stay cool on my boat, but I have 910kv motors. I really think that you should get new motors for it, belive me I know how hard it is to get burned esc smoke and smell off the hull(if it wont burn the boat first)...
                    But I understand that you want to try it so start with small props and short runs.
                    -Pate
                    • martno1fan
                      Banned
                      • Jan 2011
                      • 238
                      #160
                      I agree you need lower kv motors.
                      Mart
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        #161
                        I have to agree about the twin KB's...............not very efficient to start with and run HOT. Together they may put out half of what a Leopard 5692 does wattage-wise, so dont expect any big speed. Start with the smallish props.
                        • FastVee
                          • Aug 2008
                          • 649
                          #162
                          could not drive the boat today... weird motor issue. It spins kinda jerky/studders and wont go full throttle at all. When I pulled the wires slightly is awakes... opened the motor and no visible shorts or anything else...
                          Maybe the coating on the wires is coming off and shorting it? -need to think what to do with it.
                          • Boaterguy
                            • 1760
                            #163
                            could be a bad connection, when one wire is unplugged it does about as you described, check if the solders are good.
                            • FastVee
                              • Aug 2008
                              • 649
                              #164
                              Checked the solders...everything fine(like they should be, (Glad I have soldered so much in my time so it is kinda impossible to do bad job at it... Anyways... -)took the motors apart, EVERY wire had direct contact with the front end where the wires go in.(not the whole time,but when the wires got moved they shorted into the can) re-routed the wires so one wire comes out of one hole and 2 from another.Originally they all came out the same hole and they rubbed the plastic coating off the wires somehow so glad I solved this in time! Now there is new shrinktube on every wire and so fas so good...will test drive later today.
                              That shorting issue must be the reason why one motor draw only 2500mAh and another 4500mAh last time I drove this.
                              -Pate
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3480
                                #165
                                -Pate
                                That's a great idea. Also, where the motor wires come out of the motor, adding some silicone to absorb the vibration will help. I try to do this on all of my builds as I've had similar issues with other motors that allow the winding wires out of the motor instead of using stranded.
