hey guys ive got my rudder and stinger in from ose today and im needing some info on how to position them on the transom along with the other pieces like trim tabs and stinger thanks guys!
help delta force 35 hardware install
If you search on here you can find all the info without going into great detail as I'm responding on my iPhone not my laptop otherwise I'd post the link, but ray fullers site, fullers fast electrics has some good illustrations last I knew as well...
On another not what are you powering it with? That would be a great hull for a $70 castle/neu 1717! -
I think he is very correct... Don't use it... I had a 1521 in my df33... Good setup... A castle/neu 1520 would work ok as well... 1717 would be ideal IMHO ... With a turnigy/seaking 180 is what I would use...just cause I've had such great luck with those esc's as well... They have a 360 amp burst rating as well... Is your 1515 a castle/neu or a straight neu? Either way list it in the swap shop it will sell in a hurry...Comment
Yeh that esc should be fine... Just as long as it doesnt suffer what some folks are talking about Involving that particular speedo where after you let off the throttle it takes a second or two for the throttle to actually "back off" kinda scary with a big mono that doesnt wanna stop... I love the turnigy/seaking 180's they have been absolute bulletproof for me... I'm sure the swordfish is good too and will work well just would want to make sure when you let off the throttle the boat immediately responds ...Comment
You can use this boat which runs great as a guide, it is bigger but the idea is the same In mine I have the rudder about 2.5" from shaft centre
http://forums.offshoreelectrics.com/...ad.php?t=20054Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/Comment
hey guys help me out here a question reguarding running 2 6 cell 3600 mah venom lipo's do you think it would be to heavy to run 6s2p in this hull they fit good between the stringers and the hull just didnt know if it would be to much weight what will be inside will be the 2 6s venom packs the cc1717 motor and swordfish 200 esc and servo with basic mounts no box.. any info would be awsomeComment
hey guys help me out here a question reguarding running 2 6 cell 3600 mah venom lipo's do you think it would be to heavy to run 6s2p in this hull they fit good between the stringers and the hull just didnt know if it would be to much weight what will be inside will be the 2 6s venom packs the cc1717 motor and swordfish 200 esc and servo with basic mounts no box.. any info would be awsome"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
