Hi guy's for some reason i always liked my ABC fighter 550 boat and now i decided to make it brushless Here is the motor i am going to put in the boat and run on 2S do you think this will be good enough for this boat?
I know they are the small 380 sized motors in a 540 size can and i do have a 3300KV motor the same type but run it on 3s in my apatche 24 and it works well so i figure the extra KV will make the smaller 550 boat work pretty good.
what do you guy's think?
Specification:
Watt: 400
No-Load Current: 2.1A
Load Current: 41A
No-Load RPM: 5W
Load RPM: 3.75W
Weight (g): 170
Diameter (mm): 35.8
Length (mm): 50 (Without Shaft)
Shaft Diameter (mm) 3.17
Specification:
Watt: 400
Load Current: 41A
No-Load RPM: 5W
Load RPM: 3.75W
Weight (g): 170
Diameter (mm): 35.8
