Custom 54" cat twin
  • DISAR
    • Aug 2007
    • 1072
    Custom 54" cat twin
    This is a total build starting from mold which I borrowed from a friend. It is a cat approx. 138x36 cm, 54"x 14.1".
    building boats or cowls from molds is by far my favourite part of rc boats.
    Mold was coated with PVA by spray (light coats) and then 2 passes with wax on top of it, gel coat with vinylester (2x50gr glass, 1x160gr glass, 1x160 gr carbon aramid). This was my first one from this mold and had many "tricks", so there are some minor imperfections on the inside which are easy to deal with.
    For comparison you can see the 34" sprintcat......looking very small!!
    http://www.rcfastboats.com/
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1598
    Sweet! You got any pics of the inside?
    FE BOATING: Less like a hobby and more like an addiction!
    • DISAR
      • Aug 2007
      • 1072
      Thanks, I will post some pics when I finish it, due to the size of the boat and so many steps I had some areas where the final carbon-aramid was not sticking well. Now I am repairing these areas and apply new cloth on top
      • Jeff Wohlt
        • Jan 2008
        • 2716
        You wax hull several times THEN spray your PVA on it.
        www.rcraceboat.com
        [email protected]
        • DISAR
          • Aug 2007
          • 1072
          either way it works, have tried both. this mold was wet sanded with 2000 paper, polished with polishing "cream", then 3-4 light PVA coats with spray, then 2 passes with wax. The result is very good.
          also first waxing and then PVA is possible, but the PVA may not adhere well to the surface because of the wax (may create runs and sags)
          • bonewar
            • Jan 2008
            • 549
            All i can say is...............
            AWESOME MY FRIEND !!!!!!
            CAN'T WAIT TO SEE THIS BABY FINISHED.
            Bonewar
            SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
            • DISAR
              • Aug 2007
              • 1072
              Thanks!!! it will take some time.....I don't want to rush, want to make it good...
              • blackcat26
                High Speed Junkie
                • Sep 2009
                • 1598
                Are you putting dual 1717's in it?
                • DISAR
                  • Aug 2007
                  • 1072
                  Yes, twin with 1717s, turnigys 180, 6s, 447 L&R or 450/3 L&R, speedmaster long struts
                  • Jeff Wohlt
                    • Jan 2008
                    • 2716
                    I was just mentioning how it is usually done. Yes, the PVA has to have several very light coats. Surprised it layed up because the PVA gives it something to adhere so the epoxy can be spread. I usually put the first coat of epoxy on...even two coats then wait until not hardly tacky then lay my first FG layer on using something like 1/2 oz or 3/4 then go up from there with some 4-6.
                    It is looking excellent!
                    www.rcraceboat.com
                    [email protected]
                    • blackcat26
                      High Speed Junkie
                      • Sep 2009
                      • 1598
                      Any updates?
                      • DISAR
                        • Aug 2007
                        • 1072
                        Yes, the first one had some imperfections on the inside and repaired them but at the end I was not happy with the look. therefore I made another one which came out quite nice. the weight of the bottom part is 1.7 kgr which is quite good
                        • blackcat26
                          High Speed Junkie
                          • Sep 2009
                          • 1598
                          Looking good. Gonna be tough as a nail when you get done!
                          • DISAR
                            • Aug 2007
                            • 1072
                            Thanks, the carbon kevlar 180gr is really strong and light, but very difficult to handle it, needs a lot of effort and tricks to stick to the corners
                            • JackBlack26
                              • May 2007
                              • 905
                              Bonewar
