Bought them used in the Swap Shop.I dont know where you can buy them new at.They are Align brand motors-I guess do a search on them.
Triple Cat
align
Those are stock motors for the Align 600 e heli. readyheli.com has them in stock new. The 600L motor is a crap shoot with some of them being not very tolerant to heat. The newer 600M motor almost eliminates that issue and has a longer mean time before failure rating. Ask me how I know. you can find them new and used on runryder.com as well. Some guys buy the kit and sell the motor out of it and go for high end aftermarket motors from Xera, Plett, Neu or Actro. fwiw. Might find them on ebay but stay away from the 600L new on ebay chances are they are the troubled ones that got unloaded. jmo
Larry c ya at the pond soon!Gas Segad / Gas Rigger / Radtek carbon cat / micro fe rigger / fe ***** in workComment
no fear
Remeber they were air cooled only under the canopy of a 7 to 8.5 lb heli with the pilot doing stunts that would destroy a full scale heli running very close to wot. In your application I can't see heat being an issue. I was just sharing nfo.Gas Segad / Gas Rigger / Radtek carbon cat / micro fe rigger / fe ***** in workComment
what about the Castle 1717 air motors that are the TRex 600 replacements?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
scorpions
I've had 6 or 7 scorpions and have yet to own one that I did not like. Got one in each of my helis and plan on putting 2 in my mini cat. You must service the bearings tho. No big deal,,,a drop of oil for every 5 or 6 flights or ceramic bearings.
They even sound different with the ceramic bearings.Gas Segad / Gas Rigger / Radtek carbon cat / micro fe rigger / fe ***** in workComment
My wattmeter said the castle was more efficient than the scorpions and slightly more powerful than the align motor but I could bog the castle easier than the scorpion. I had to try hard by doing pitch pumping tic-tocs but the castle was easier to bog on the same pinion and setup.Gas Segad / Gas Rigger / Radtek carbon cat / micro fe rigger / fe ***** in workComment
That's really different, I like that concept.
As of the Align 600. Personally I think the benefit using outrunners in boat was the cost. But as Leopard join the market this advantage today no longer exsists. You don't want to hear my sad story with Align 600 motor. It ended up with a nice looking white magic smoke in my 1/8 buggy after only approx. 1 minutes of its debut run, and that wasn't a hard run. The cooling jacket does very little help if any. The motor will soon become a warm hearted cold man who's really warm inside. Actually you can tell what they're capable of by just watching the 3 slim wires.Comment
Hull has been stunged.Got the stingers mounted.Still have to mount the strut/rudder for the center.Im also open to outrunner motor suggestions.Im kind of paranoid about the Aligns with amp draw/heat.Wouldnt mind running Scorpions,but dont know which ones.Id like to have 1800kv motors for 6s running.Any ideas?Comment
Got the strut/rudder mounted.These pics are just mock up with props stuck on for pictures.Its pretty tight back there with 3 X447's hanging there.Im hoping to get the rest of my parts soon.Im kind of getting excited to run it now after seeing 3 props on it.Attached FilesComment
Now don't take this the wrong way Larry because you've been doing this fe thing longer than me but I'd like to ask a couple of questions. Just doing some 'what if' math with some good 30-40c cells. 1800kv x 3.5 x 6 puts your motor @ 37800 rpm. Are there props that can actually move water and ultimately your boat at that rpm? And how much energy will be wasted and turned into heat if the motor can't reach the sweet spot? With that said I used to set up my 12s heli for a given head speed and selected motor kv based on what I KNEW that head speed was. You've been playing around wit these cats and have an idea of what a certain prop will do with so many cells in a boat that weighs whatever. There's my 2 cents and btw scorpion has some sweet new motors if you can shoehorn 40 mm in that hull 3 times or if you know something you'd rather not share here's the 30mm motor I ran in my 500,,, http://www.scorpionsystem.com/catalo...S-HK30-1900KV/ Just plain stupid power on 6s. There is something to be said for 1400 watts x 3=4200 for sure. I want to see this boat fly, I'm very interested, actually excited and wondering if grown men should be this excited about toy boatsGas Segad / Gas Rigger / Radtek carbon cat / micro fe rigger / fe ***** in workComment
