Todays vid.................quite pleased, temps still insanely low...............guess a 645 is next, should get me to 60! EDIT: this run is with an x447 up from a 445 in the previous vid. 53.5 mph gps'd
39" Mono, Castle 1717 build.
Last edited by Make-a-Wake; 12-16-2010, 12:38 AM.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
http://forums.offshoreelectrics.com/...est!&highlight= -
sounds good.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
do you have any offset on the shaft to the right or it is centre?
it runs very well, seems like it can handle more speedTwin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
Very nice boat, what about torque effect? I' building a 39" MHZ with the same motor. I will try 2 rudders and Speedmaster stinger. Too much torque for a 39" mono? ThanksComment
No offset.................
What do you alll think of trying an x645...........went well with the 445 and 447............seems like a 645 would be next in line.......
I'm concerned about the T180 ESC. Thoughts?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
http://forums.offshoreelectrics.com/...est!&highlight=Comment
If your motor and speed control are low temp'd I would step up and try the 645. Do a few passes and bring her in and check everything. A 447 actually has less total pitch than a 642 does. If it was me I would try the 645. If that looks good I would prolly skip the 646 and try a 648.FE BOATING: Less like a hobby and more like an addiction!Comment
I have a 642 and was thinking that would actually be a slighter step up from the 447.........but the dia. is pretty small..................so 645 i guess............NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
I always refer to the prop section on this site and look at the numbers to make my prop decisions. Now put the 645 on there and kick it!FE BOATING: Less like a hobby and more like an addiction!Comment
Awsome ! $90 Speed controll running max volts in a 39" mono. I am 110% sold on the 180's !"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
Thanks rearwheelin'................. I own several T180's and they are darn near bulletproof. It has been mentioned that they have tested at more like 200 amps constant. The BEC's have always worked..............
I threw my 645 on but the prop hub is smaller than the 447 hub so it looks goofy with the big drivedog...........no smooth transition.......and the hub is shorter too. Gonna order an x450 and probably use it as my final choice as it 'may' hit 60mph, i'm more than pleased with the solid, cool running setup and im not "racing" anyways.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
I have modified aeromarine drive dogs with a dremel to fit smaller prop hubs, there drive dogs are 3/8 o.d. and strong.Thanks rearwheelin'................. I own several T180's and they are darn near bulletproof. It has been mentioned that they have tested at more like 200 amps constant. The BEC's have always worked..............
I threw my 645 on but the prop hub is smaller than the 447 hub so it looks goofy with the big drivedog...........no smooth transition.......and the hub is shorter too. Gonna order an x450 and probably use it as my final choice as it 'may' hit 60mph, i'm more than pleased with the solid, cool running setup and im not "racing" anyways."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
Ok.........finally threw the x645 on. Still got a bit of tweaking to do...........there's a bit left in it i think.
Vid edited down to save time, think i got the top gps pass here.
is this the biggest prop yet for this setup?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Yep. so far..................i think a may try an x450-452 for more diameter though.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
