AC R42 Twin Outboard
  • timjz
    • Aug 2008
    • 271
  • Make-a-Wake
    FE Rules!
    • 5557
    This 3660 comes out of the side
    • timjz
      • Aug 2008
      • 271
      Look close at the pic - It says "L-4074-2200KV"
      • Make-a-Wake
        FE Rules!
        • 5557
        Well crap...................thats retarded to use that photo. I wonder what the 3660's really look like now...................?
        • Make-a-Wake
          FE Rules!
          • 5557
          This link shows a schematic of the motor at the bottom................shows the wires out of the top.....................hmmmmmmmm.
          • timjz
            • Aug 2008
            • 271
            I agree. Take a look at the first link, it has a drawing showing the wires coming out the top. I would think an extra 4mm on the dia. should be fine.
            • Make-a-Wake
              FE Rules!
              • 5557
              Me too, 2mm per side really....hope you dont overpower the drive on those PB outboards with the big 40mm 4 polers.
              • timjz
                • Aug 2008
                • 271
                Would the esc's handle those motors? I'm not sure which wind to get.
                • Make-a-Wake
                  FE Rules!
                  • 5557
                  I'd go with the 1900kv........................4s would be plenty..........you could run a couple of these props - http://www.offshoreelectrics.com/pro...od=dh-aqub9760
                  Make sure the 40mm jackets arent too wide diameter-wise if you still want to use the cowl. The t120's should handle it fine.
                  EDIT - just realized those props arent L/R available................you could use Octura x442's they come in L/R rotation.
                  • steveo
                    • 1454
                    i have a suggestion for a cowl, i have used a cowl from a proboat blackjack 26 really not the whole cowl just the cockpit maybe you could do the same with a blackjack 55, i assume your boat is 42" i know the bj 55 is larger you maybe able to customize it using to fit your needs
                    • ScarabChris
                      • Oct 2010
                      • 752
                      Cool....another twin outboard build. Were there so many outboard builds before I came in here?
                      • timjz
                        • Aug 2008
                        • 271
                        I've had this in mind for quite a while now. First I was going to put twin OS 21's on my Dumas Skater, but I just didn't feel like messing with nitro anymore. Then the electric outboards just didn't look right on the Dumas. 2 boats & 3 sets of motors later, this is how my project ended up.
                        • wparsons
                          • 461
                          I don't think you'll find right hand cables for the lower unit, but I might be wrong.
                          Light travels faster than sound, so people may appear to be bright until you hear them speak.
                          • Make-a-Wake
                            FE Rules!
                            • 5557
                            Yeah.............thought about that too, its why i posted the 40/57 first.........then thought he may want counter rotation..........he could fab a right hand cable possibly.
                            • timjz
                              • Aug 2008
                              • 271
                              Cables are already taken care of.
