Hi
I have started a new rigger and here are some picture of the build.
It a 1,28 meter (~50 inch) long rigger about 16 lbz. It will be powered with a lehner 3040/12 (875 kv) with lipo 10S2P. ESC is an YGE200 Navy.
EPR 5000 means in french "nuclear plant 5000" and in english "Electric Propulsion Rigger 5000 watt"
the boat is design for oval racing with 90 nitro riggers.
CDG is of course a real question. The implementation in the following:
2 lipos in front, the motor and 2 lipos in the back. The weight on the strut could be in a range of 700 gr to 1,2 kg (eg 0,9 lbz to 2,1 lbz).
My calculation based on rpm and propeller size (likely to be an octura X460) is that the right position of the CDG is obtained with a weight of 1,5 lbz on the strut.
The flex wire is about 60 cm long: Rember the the motor can move backward and forward in order to cope with flex wire length reduction. I hope that it will work well and that the flex will not blow up.
Feel free to help me as I have not found many similar projects
regards
Pierre
regards
Pierre
