Delta force build
  • Basstronics
    • Jun 2008
    • 2345
    Originally posted by Brushlessracev
    Mine is not even being detected by the module. I order another i hope its not the module its self the green light just keeps flashing i think its ether supposed to go out of stay on when receiving from satelights. tell me if i am wrong.
    According to the directions when you hook all of it up it will blink until it has acquired a GPS fix then it will go out. This can take about a minute.
    My last run I hooked it all up and it was blinking. I tape the GPS receiver to the underside of my hatch. Also note you need the square receiver part facing up.
    To my knowledge it was blinking the entire time I could see it. But by the time I got the hatch taped up and in the water I had a GPS fix and managed to log.
    I cant say Ive had one problem with the Eagle Tree. It does what its supposed to do.
    • Basstronics
      • Jun 2008
      • 2345
      what do you mean move forward? i just ask a question!!!!!!!!!!!
      It was a polite way of asking him and hopefully others not to dwell on the previous thread and start over. Which is what Im doing.
      I think your intelligent enough to understand what I mean here. Lets move forward.
      • Rich
        • Jan 2008
        • 551
        The gps can obtain a 2D fix while the L.E.D is still blinking. If you have followed the directions it should work. Try setting the logger to record ONLY WHEN THE GPS HAS FIXED, this will tell you if you are at least getting the 2D fix, good luck
        • Basstronics
          • Jun 2008
          • 2345
          And also note it doesnt work indoors and sometimes in the boat if its buried beneath things.
          • Chuck E Cheese
            • May 2008
            • 1684
            mine goes out when it links, i think the blinking is "looking for satalites" it took about 5 minutes the first time, then about 1 minute the first run and 10 seconds after that. just plug it in and let it sit out in the open for 5 minutes and see if it works. make sure you are in a open area and dont move it much..
            see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
            • Brushlessracev
              • Oct 2010
              • 136
              I tried for 20 min but nothing. did you waterproof your eagle tree or did you leave it. i was thinking of covering mine in epoxy but i did not know if it could take it.
              • Brushlessracev
                • Oct 2010
                • 136
                Originally posted by Basstronics
                Its awesome, you will enjoy this.
                No more guessing or wondering.
                I was shocked at what my 25" Delta Force knock off is doing.
                what are the specs on your knock of 25" how is run.
                • Basstronics
                  • Jun 2008
                  • 2345
                  #23
                  http://forums.offshoreelectrics.com/...ad.php?t=19121
                  Speed - Electric - Prince 25 Mono - I thought I would start a new thread for this boat since it seems to be getting popular but there is not much info out there yet on it. I ordered mine from http://r2hobbies.com/products.php?cat=58 and should be getting them any day now. They did not have white ones in stock so they
                  32 pages of reading pleasure. People have been playing with these boats for a bit now. Theres another thread started by 785Boats (or a name like that) called "bulletproof" somewhere. Lots of good solid info on these boats.
                  I think Im gonna sell it and move into something larger and faster.
                  • Brushlessracev
                    • Oct 2010
                    • 136
                    #24
                    May be my telemetry is not wrong there saying on rc universe guys are getting 50mph+ with 4s and a 2300kv motor thats what i am running.
                    • Chuck E Cheese
                      • May 2008
                      • 1684
                      #25
                      you can get close to 50 with that set-up. i used a df 26 with cc120 and ammo 2300 in teh high 40's on 4s, it takes alot of set-up and pulls about 100 amps..
                      • Brushlessracev
                        • Oct 2010
                        • 136
                        #26
                        According to my spectrum my 8th scale truggy is hitting low 70s. with a teken rx8 on 6s.
                        • Brushlessracev
                          • Oct 2010
                          • 136
                          #27
                          So i am glad i went with the 120 amp speed control last set up i had the turnigy 80 speed control and a SuperVee 27 on 3s. Seems to be a lot faster on 4s and a 11L and the seaking 120, same as the turingy 120 just relabeled, hope i get my GPS for next weekend too really know what it does.
                          • Brushlessracev
                            • Oct 2010
                            • 136
                            #28
                            Finaly got a decent run in here is the data from Eagle tree.
                            • Basstronics
                              • Jun 2008
                              • 2345
                              #29
                              Nice.
                              You got about 50 watts more power than me on the 4S. I see its less Amps also. Only 1 mph slower... Not to shabby.
                              What prop?
                              Heres my breakdown:
                              156 Amps
                              1549 Watts
                              37 MPH
                              On a Graupner K42 prop. Worked awesome!
                              • Brushlessracev
                                • Oct 2010
                                • 136
                                #30
                                Nice.
                                What prop?
                                Heres my breakdown:
                                156 Amps
                                1549 Watts
                                37 MPH
                                Grimracer 40x52/3 running 4s i think i could prop up a little.
