Hello All:
About 9 years ago, I was into gas boating (zenoah's), and have been inactive sence then. Now, I have discovered FE. This home built hull will be my first electric boat.
Back then, I built 6 or 7 hulls, mostly plywood over foam, cats.
Took one of my hulls and cut the center out to yield 2 nice, 41 inch, sponsons.
Now building a narrow, 7 inch wide center to glue between the sponsons.
I got a aromarine sprint cat 44 inch hull with an 8 inch center. I figure there will be less lift on a 7 inch wide center, and I'll get more speed before it blows off.
Got the 7 inch wide center built, with a Leopard 5692 motor all mounted up and water cooled.
Have a 12S 5000MaH battery, and a Castle ICE 160 HV controler (I will water cool the controller). Motor is 730 KV, so I'll get about 32000 RPM.
The hull is incomplete, but it looks like it will have a RTR weight of 11 pounds.
Looking for 60 to 70 MPH. I think theres plenty of power. I think speed will be limited by the hull blowing off the water.
I have fooled around with the CG and can get from 34% to 45 % by adjusting the battery position.
Pictures to follow.
Mark
Pictures to follow.
Mark
) and try it again. Thats the problem with building your own hull, you have to guess at a lot of things.
