I'm looking at building up a DF 26 or 32 (or copy, but likely a real one since the price on the hull isn't terrible at all!) over the winter, and am looking for some suggestions on gear.
Is there any value in running an XL size motor in the 26" hull, or does the power give more speed than the hull can handle setup for oval.
Realistically, what speeds will either size handle and still be drivable on less than perfectly still water?
I was tentatively thinking of the 26" hull, 540xl motor around 2000kv (maybe as high as 2300), 120amp esc to be safe (unless I need more?) speedmaster stinger and rudder, and whatever trim tabs and turn fin that look right. I plan to run it on 5000mah 40c 2s in series.
I was looking at the knockoffs, but it looks like if all I want from the package is the hull/hardware it's cheaper to just buy the hull and hardware separately and build it myself.
Ideally I'd like it to be in the speed and handling range of a 3.5cc v/mono, but I wouldn't complain if it was faster :D
Am I in the right ballpark at all, or way off target? Any suggestions and input would be greatly appreciated!
