Villain with a 700 single drive
  • kahnen
    • Jul 2007
    • 77
    Hey everyone, my first time posting here, though I've read these forums for a while now. Some of you have helped me and probably not even know it
    Anyways, I converted my villain IV to a single drive with a 700 motor. The actual build is on another forum, but I wanted to show you guys too what you help me create. Thanks
  • SJFE
    • 4735
    Boat boogies man. Nice job!!
    • kahnen
      • Jul 2007
      • 77
      Heres a new video running 14 cells and a CF45mm prop, need some turn fins its a handle full now. Transom of the villain is "odd" shaped, might be hard to find one that fits without mods. Enjoy.
      Oh and thanks SJFE.
      • kahnen
        • Jul 2007
        • 77
        OK, instead of starting a new build thread I decided to revive this one since I will be going brushless with this. I'm getting the mystery 80 esc from the freebie giveway and was wondering on a motor choice for it. I'm not looking for insane speeds, just more. It'll run on 12-14 cells. Yes NIMHs I think the wieght will help keep it in the water. I was thinking a range of 1500- 1800? Does that sound good? Maybe the proboat motor or SV or just a Feigao one? This will be my first brushless motor but I have read alot on the subject. Thanks for the
        • kck741
          • Aug 2007
          • 265
          Lets see if your not looking for insane speed but an honest good dependable motor I would go with the sv motor,It has loads of torque.But I really dont know about the ESC I have never fooled with one of those
          S.S.R.C-Southern Style Radio Control
          • steveo
            • 1454
            maybe a 10 or 11 xl on 14 cells might keep the amps down for that 80 amp speed control and put a fan on the controller, just to be safe
            • txboatpilot
              • Oct 2007
              • 1494
              BJ26 or SV27 motor would be great.. Lots of torque..
              Nothing like keeping you lipos warm and your prop wet!!
              • kahnen
                • Jul 2007
                • 77
                Thanks everyone, I ended up getting a proboat motor from FEChris. Anyone know if this esc can be water cooled with like the SV esc plate?
                • kahnen
                  • Jul 2007
                  • 77
                  Well, I'm all ready, just waiting on the motor. And since I was buying stuff for the build, I couldn't help myself and splurged on some lipos
                  So the specs will be
                  proboat motor 1500kv
                  mystery 80 esc with a cooling plate and Pistix
                  4s1p
                  .150 flex cable
                  most like the CF42mm, though I got a 40mm to try first.
                  Speedmaster stinger
                  custom rudder
                  And we got more snow, to make it that much more frustrating.
                  • SJFE
                    • 4735
                    @ just over 23000 rpm unloaded it will be a nice sport setup. The amps should stay down and your run time should be decent. Pick up a 42 & even 45mm prop for a few more mph.
                    • kahnen
                      • Jul 2007
                      • 77
                      Thanks and as luck would have it, I do have a 45mm already.
                      • Hydromaniac
                        • Oct 2007
                        • 816
                        Cool project.
                        Its neat to see some of the conversions that can be done. I had done a single brushless conversion to a Traxxas Villian a while back. It runs quite well and can really handle rough water. here are a couple of photos and a vidieo of the finished product. here is the video link http://www.putfile.com/hydronut. Click on "Super Villian" You may have to let it play through once then replay it to eliminate the broken up effect. Hope you enjoy it.
                        www.rockymountainthunderboats.org
                        • kahnen
                          • Jul 2007
                          • 77
                          That looks awesome, you make the hatch yourself? Right now I'm just useing a flat piece of plexi to seal it good. I wanted to use the orignal hatch but there just wasn't a way to seal it tight
                          • Hydromaniac
                            • Oct 2007
                            • 816
                            Yes I made the hatch from some pieces laying around the shop. Like you I didn't think the original sealed well at all. So I closed up the opening and made it much smaller then built a hatch cover to fit within the new opening size. Rather then build it to look like the original pleasure boat style I decided to give it a bit more of an enclosed offshore look. It is now completely watertight.
                            • justneedspeed
                              • Jan 2008
                              • 112
                              http://www.youtube.com/watch?v=g84KYQHofyg
                              Kahnen how did you convert your villain to a single drive. Can i see pics if you have any. My friend is think about doing that Thanks in advance.
                              always need just a few mph more
