Thanks for the compliment fella's. I have also used lead shot inside of a small dia pipe. Seal off the ends with melted wax. Can be put just about anywhere.
The 4s batteries may also be put on each side to move fore and aft.
You think it looks good in the pic......you should see it in person
I have to admit the build was done by Madmikepags on RRR. I will give credit to him as he did a clean build. I swapped the rudder an put the Speedmaster extended rudder because if you look in the earlier pics it was a wedge style Hydro rudder. I decided to go with the Lehner for all out power. I really cant wait to hear this baby sing her tune...
Here is what I do.
I have a pipe that starts front of the motor and runs all the way up in the bow following the keel line.
If I need the CG more forward that I can get with the batteries Ijust add some lead up front in the pipe.
My batteries can be moved changing the CG between 32 and 34%
Hopefully 34% will be enough when I have found the right prop.
Anbjørn
I been sayin it, we need to find a central spot to run between your location and mine so you, myself, and Todd can run! I'd love to see it up close!
The batteries were just placed thee for pics. I will put them port & starboard of the rails with battery tie downs. This is what will allow for the CG adjustment.
