Hi All,
I am running the following setup in a Graupner Systems Cat:
Feigao 540 12XL
Turnigy 180 ESC
Turnigy 5000Mah 20c 6s
x440 prop
I do have a slight "S" bend in my flex shaft as a left over from my brushed power system.
I did a test run and the boat flies! I did 1-2 minute runs and checked temperatures. After the first run I was at 105F. After the second run I was at 135F. I waited for the temps to drop to 120F and did another run and got to 140F. All temps were taken on the end of the shaft.
I would like to be able to run a full battery without worrying about temps but do not feel comfortable with my temp rise numbers (ambient was 68F).
So, I can move my balance point back a bit to get the hull up a bit but will this help amp draw a lot? If so great!
I notice that I get about 6' of cavitation on startup but then the boat takes off on plane. Can I reduce my prop size to an x438 to try to reduce amp draw? Does it make sense to detounge my x440?
Finally, I notice I get no rooster tail at all when running fast. The bottom of my strut is about 1/8" up from the bottom of the sponsons and parallel to the bottom of the hull. Should I raise it up a bit? Will this help amp draw at all? Will this cause more cavitation?
Any advice is much appreciated,
Mars
Feigao 540 12XL
Turnigy 180 ESC
x440 prop
Mars
