Since these are only going to pull 60-65 amps per side, I thought I would find out.
Will a Turnigy 120 hangle 6S?
HobbyKing's website recommends an esc around 110-120 amps. Being a twin with less load on each motor you should be ok. What props you running? 442's?FE BOATING: Less like a hobby and more like an addiction! -
I run several Turnigy 120's on 6s.........mainly with Feigao 540XL's................they work fine.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
http://forums.offshoreelectrics.com/...est!&highlight=Comment
I would disable the BEC. Even the Seaking (turnigy) 180 doesn't like 6S on the BEC.Mini Cat Racing USA
