Project Osprey!
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    Originally posted by befu
    I never used the saran wrap method. I just coat one piece with a thin layer of vaseline, then silicone the other piece and press them together. No wrinkles to leave water channels that way.
    Also, once cured and taken apart, you can keep a thin layer of vaseline on it to help it keep its seal.
    I am very interested in this build to see the results. Speed, handling and power consumption. I am building a 40" deep vee, but I am going scale offshore boat. Maybe Miami Vice so I can wear my loafers and white blazer with pastel T-shirtwhile running it! Might build two, one very scale and scale like speeds, the other for faster speeds.
    Brian
    Yeah, the next step is to put a nice smooth coat over the wrinkles. Never thought of using vaseline... that might work better than the corn starch did. The final coat will be against a some tape down in the hull to keep it even and prevent sticking. I've just had so many problems with silicone sticking to the hull...
    I have two more to do still, so have some room to experiment.
    • sailr
      • Nov 2007
      • 6927
      I thought I read somewhere that it was too big to ship to the USA?
      Mini Cat Racing USA
      www.minicatracingusa.com
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3480
        The post man delivered it, registered mail. Right out of the back of the mail truck. It's a BIG box. 130x38x26
        • TwzteD
          • May 2010
          • 91
          any results with speed and what not? how fast on 4s?
          • TwzteD
            • May 2010
            • 91
            also i noticed you said that you moved the battery trays, how did you loosten up the epoxy to move them or take them out?
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              Warmed them up, not hot just decently warm, and gently applied pressure and they popped right out. They aren't really well glued fortunately. I used a "widget" razorblade, like used to remove stickers on car windshields and gently scraped the excess glue off.
              Then epoxied them were I wanted them. =)
              No runs yet. Might be a couple days, my other half is off work for a few days. Time with her always comes first.
                • 9488
                I'm glad you got one of these, I would love to hear how it runs stock..
                I'm either going to get one of these or the new Traxxas Titan
                • bustitup
                  • Aug 2008
                  • 3071
                  #23
                  Originally posted by Rumdog
                  you got a link where to buy those locks? I installed aquacraft cowl locks on my 39 mono and they are crappy plastic. Broke on as soon as i tested it out. POS
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3480
                    #24
                    OK, got the maiden run in!
                    Well, I got to spit water around the pond anyway. I didn't adjust the stinger and the stock angle is up about 6 degrees. Which was about like driving a Corvette in a snowstorm.
                    I hit a top speed of 30mph, but with a 15 ft high rooster tail and it took about 10 seconds to reach top speed, still clearly slipping.
                    So, I really think this is a 40+ mph setup, but will have to wait another day to see for sure!
                    This time, I'm bringing tools to adjust the stinger.
                    Wonder what a Little Screamer would do in this hull?
                    • Punisher 67
                      Ignore list member #67
                      • May 2008
                      • 1480
                      #25
                      Great info , awesome thread . these look like DF knockoffs and with a little tlc could be made to be great runners for the price
                      Necessity is the mother of invention.............
                      Youtube Video's http://www.youtube.com/user/Titanis2000
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3480
                        #26
                        OK, got some video, it's uploading now. I don't know what's causing the large amount of cavitation. It's acting like a sports car in the snow. SPIN! SPIN! SPIN!
                        Thanks Pete. =)
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3480
                          #27
                          Osprey Cavitating-
                          Vid One: http://www.youtube.com/watch?v=c14vSAp76kw
                          Vid Two: http://www.youtube.com/watch?v=nxestCH0eUA
                          Here's a photo of the stinger:
                          • Rumdog
                            • 6453
                            #28
                            It's a big mono. It needs a big motor, and a big prop. The gear is more suited to a 30" mono.
                            • Punisher 67
                              • May 2008
                              • 1480
                              #29
                              I have to agree with Ryan , It might need a shade more prop
                                #30
                                It's a good thing it's cavitating or that little motor would be toast by now. A hull that size needs a minimum of a 55mm prop to run fast and efficiently. The little 540 motor isn't up to the task, no 4S motor with a 2200 Kv would be unless short run time and excessive temperatures are desired.
                                An interesting exercise - now put an 8S or 10S setup in it and get serious.
