Darin's 19T Spec N2-Hydro...
  • Darin Jordan
    • 8332
    The CF I have is from a previous purchase from Graphite Eligance... but they've been on "vacation" for about a year now... I think you can get graphite sheets from McMaster-Carr, as well as a couple of other places...
    Darin E. Jordan - Renton, WA
    • deestingray
      • Jun 2007
      • 51
      Darin,
      That is a lovely looking build there, I am digging it for sure. I bet it would feel like a bit of an "old skool" boat, using the brushed motors and alike. I have a question though, what kind of amperage are you guys pulling in these and what sized props do you use? My question because I have a 21 turn lying around doing nothing that I was going to put into a 20inch shovelnose.
      • andym
        More Go Than Show Prop Co
        • 2406
        Darin mate is that a scratch build or kit? Looks like a lot of laughs for cheap. Well done on the nice build. Oh by the way you should try 5s 7xl and x637 on your TP2, cant turn but straight line is a blast!
        • Darin Jordan
          • 8332
          Andy,
          It's kind of a "scratch built kit"... Brian Buaas designed it, and cut out all the main formers for a bunch of us in the club... Then the decking, motor mount, transom, nose-pieces, and all of the carbon reinforcing, etc., was all done by me.. They are a lot of fun... These ones are VERY lightweight and somewhat flimsy... they'd explode on impact if Brushless powered, but the 19-Turn setup with a light battery and such seems to work well... Just a fun little rigger spec-class that's very easy on the pocketbook...
          Not sure what kind of amps we're pulling... I suspection not much over 30-40... Only the motor gets warm, and it's only getting to 130-140 after a run using a de-tounged X632...
          As for the TS-2... I haven't tried anything new on there... In fact... I have the second one back on the bench now and it's getting a MAJOR overhaul the the sponson ride-pads... It won't look much like a TS-2 there when I'm done!
          Also, on the tunnel front... I have a 3.5 WoodStuff 28.5" hull on the way that I got from a guy on International Waters... And I'm also working on getting another 3.5 hull that will be VERY special from an old aquaintence who used to race here but moved away.... If I can get THAT one... I think we'll see a VERY fast FE tunnel here in the near future! I'll keep you informed...
          • Darin Jordan
            • 8332
            It's BAAAAACCCKKKKKKK!!!
            It's BACK!
            I pulled this boat back down off the shelf, and have decided to try something with it.
            Since building this, it's been through quite a few different configurations. The final setup was using a brushless power system on 1S for M2-Hydro 2-Lap duty. The built configuration was damaged during an attempt when I clipped a buoy and broke off the sponsons.
            SO... I've decided to take the set of JAE style sponsons I have had built for quite some time, but never used, and adapt them to this hull. It will look similar to the configuration in the attached picture, which is my current N1-Hydro SAW boat. I originally built these JAE sponsons for that tub, but never used them after making some SAW specific sponsons.
            Power system for the new setup is going to be an N2 Hydro power system, sort-of...
            I've already made some "adjustments" to the sponsons to make them work better for oval racing, and am currently looking for a suitable turn-fin for this type of sponson/boat.
            I've also dug out an old set of Fuller's Crumb-Grabber hardware that I'm mounting up. I'll get some pics and post them as soon as I get them uploaded...
            We'll see how it works out, but it'll be better than just having it hanging on the wall!
            • cjs
              • 322
              Darin,
              Can you give us some details on your strut/driveline setup? Are there bushings or bearings in the strut?
              -Chris
              • Darin Jordan
                • 8332
                Originally posted by cjs
                Darin,
                -Chris
                1/16" Wire drive... brass stuffing tube JUST through the hull (exposed wire back to the strut)... Fuller's 6-8 cell sized strut... Two different struts, depending on the prop I prefer to run... Octura lead-teflon bushings for 3/16" stub... Boca Ceramic/Stainless bearings for the 1/8" stub. The nose piece has been removed from the strut and I made my own aluminum cone pieces that capture the front of the stub-shaft at the strut.
                With the power system I'm looking at running, I'll likely be spinning a 1/8" stub and 1/8" ID props... (32-35mm)...
                • cjs
                  • 322
                  Is the stuffing tube just large enough for the 1/16" wire (1/16" ID stuffing tube) or is it larger? I am thinking a similar setup will work well for micros.
                  -Chris
                  • Darin Jordan
                    • 8332
                    It's a little larger... I don't recall the exact size. I'll try to measure it when I get home.... I use a piece of fuel-tubing inside the hull to seal the wire, but I know that the tubing does fit rather closely. I THINK it's 3/32" O.D., .014" wall thickness tubing, which would have an ID of .06575... I'll try to find out for sure when I get home tonight.
                    • Darin Jordan
                      • 8332
                      OK... ready for final setup and trim...
                      I replaced the previous hardware (a combination of fullers and home-made) with a complete Fuller's/Dick Crowe "Crumb-Grabber" setup that I had laying around. I needed to move the rudder to the right side, and this was a very easy way to make that happen. Reversed the servo mounting to complete this.
                      New sponsons are all mounted as well. Overall length is right about 25".
                      I fabbed up the turn fin last night from some 7075 .060" aluminimum sheet. It's essentially the JAE .12G turn fin (Thanks for the pattern, Tyler!)
                      I also have a ride-pad that fits on this boat. I haven't been using it in the previous configuration (This hull with the old sponsons is the current NAMBA 2-Lap M2-Hydro record holder), but we'll see if it needs it with this new setup.
                      Next step is to install a power system and do the final setup on the bench, then go get it wet!
                      Made the sponsons Florescent Orange so it'll be easier to see amonst the spray and rooster-tails of all of the much FASTER and larger boats I'll be competiting against! '
                      If I can find a couple more of them, the rudder will be getting replaced with a Fuller's/Hughey Stainless blade rudder. I don't have anymore at this point... but hopefully will find a couple more soon.
