Looks good buddy...
Wizards Pickle build
Got some video
ran the boat on Monday with my new Turnigy 4000 40C packs still need to find the right for them pretty close thou I may add 2 deg neg on strut any way got a little loose at he end of run this time with a X440 prop may go back to the X438 not sure I still have other props to try.
2 SV 27's and Vac-U-Pickle UL-1 PowerComment
CG Location
Please help me. Not sure what is proper location for CG ThanksAttached Files2 SV 27's and Vac-U-Pickle UL-1 PowerComment
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
Wow. My CG is quite a bit more towards the rear. Maybe that is why it does cartwheels at high speeds!
One thing I've noticed is that the pickle traps a LOT of air. It's fine at lower speeds (under 45mph). As soon as I get it above 45, it wants to fly! The air just can't escape fast enough. Has anyone considered putting tunnel vents? Just small recessed areas on each side of the tunnel to vent some of the air. I might try this with my green boat (she's getting a little rough anyway....time for a new one).Comment
Thanks guys I tried a L38/55 the other day didn't like it at all wouldn't turn right and flipped. I like so far X438 X440 grim 40/52X3 next I will try a X446 and X642 also tried a M440 but it was way slower in the turns. I had the cg to far forward will see what happens next week I've got it up to 48 mph so far but like you said it wants to fly at those speeds. Has any one run a deep strut I have it set at 13/16 to bottom of strut with about 2 deg neg
Does any one have a photo with the air dam installed?2 SV 27's and Vac-U-Pickle UL-1 PowerComment
I'll try to post a pic of a air dam tomorrow. Nothing fancy, just tape.
In windy conditions I'll add some weight (approx 6oz) under the ESC which should be just in front of the motor.
Don't discount a X442!!!!!MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
