this look about right for the stuffing tube on homemade cat?
  • dana
    Banned
    • Mar 2010
    • 3573
    i dunno what the hell im doin but i think this is the general idea. correct me if im wrong... Dana
  • bonewar
    • Jan 2008
    • 549
    Dana,
    The stuffing tube looks OK.
    The trick to getting it right is as little of a bend as possible.
    That way there is less friction on the drive line.
    Bonewar
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
    • dana
      Banned
      • Mar 2010
      • 3573
      so lemme ask this.... since my transom os flush across the back, should i use a strut that is closer or further away from the transom...?
      • bonewar
        • Jan 2008
        • 549
        Dana,
        I like to have my strut as close to the transom as possible
        to help with prop walk issues.
        The boat i'm referring to is a H&M MARITIMO CAT.
        40" LONG 10.5" WIDE.
        Your cat looks to be about the same size.
        Running the strut behind the transom works 2
        And allows for easy access to the strut if you need to adjust it.
        Theirs a couple of ways you can do this.
        with an in line rudder behind the strut
        or an offset rudder beside the strut.
        I like the in line rudder for more of a scale look.
        Bonewar
        • dana
          Banned
          • Mar 2010
          • 3573
          Well I found a really cheap aluminum strut but it's set back, maybe I could redrill so the strut is right on the transom the do an offset rudder
          • j.m.
            • Jul 2008
            • 838
            Cheap or inexpensive?
            Because you don't want cheap...
            Try this, it comes with everything you need in the way of drive hardware except a coupler:
            http://www.offshoreelectrics.com/pro...prod=ose-80085
            Jon
            • dana
              Banned
              • Mar 2010
              • 3573
              thanks but they're out of stock. inexpensive was the word i meant to use lol
