use baking soda to thicken epoxy or cure super glue instantly
  • dana
    Banned
    • Mar 2010
    • 3573
    dunno if anyone was familiar with this method... but you can thicken epoxy with baking soda. This also seems to make the epoxy cure super hard! also it can be used to instantly cure super glue. Fill a hole or chip with baking soda then a drop of water thin super glue, works instantly and can be sanded immediately. use it however you want to. mixing with epoxy will make the epoxy heavier...which i dont think is such a bad thing, because while making a super light boat will give it speed, a little bit of weight will make it more stable in my experience. Thats all! thanks, Dana
  • Jeff Wohlt
    • Jan 2008
    • 2716
    That crap must work for everything!
    www.rcraceboat.com
    [email protected]
    • dana
      Banned
      • Mar 2010
      • 3573
      lol jeff superglue or baking soda? haha
      • AndyKunz
        • Sep 2008
        • 1437
        It makes the glues VERY brittle. Brittle, as in "shatters like glass" not "tough as nails."
        But it does cure the CA quicker (watch the fumes).
        Andy
        Spektrum Development Team
        • m4a1usr
          Fast Electric Addict
          • 2038
          Andy
          I've seen that before as well. Makes the epoxy too hard and subject to shock fractures. If you want cyanoacrylate to harden instantly just add a drop of water to its surface. Instantly hardens it.
          John
          Change is the one Constant
          • AndyKunz
            • Sep 2008
            • 1437
            So does exhaling on it.
            Or touching it with your finger tongue, lips, fingers, or other body parts.
            Andy
            • dana
              Banned
              • Mar 2010
              • 3573
              well im not suggesting doing any major structural repair/building with it, but it has its uses
              • DISAR
                • Aug 2007
                • 1072
                I tried baby powder to thicken epoxy and worked well
                http://www.rcfastboats.com/
                • mappo
                  • Feb 2010
                  • 488
                  I use talcum powder!
                  Do you know what the biggest problem with the world is?
                  That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
                  • tsenecal
                    • 58
                    epoxy manufacturers claim most of these things will weaken the epoxy, but west systems makes all kinds of fillers and thickeners that work much better with the epoxy...
                    of course these all cost more than baby/talcum powder and baking soda... and they are all made by the epoxy manufacturer...
                    • AndyKunz
                      • Sep 2008
                      • 1437
                      There are different types of microballoons. They are chemically inert. Talc, baking soda, water, etc. are NOT, and as a result they affect the epoxy.
                      Also, West (and other mfgs) tell you that you need to change the hardener/resin ratio when using fillers and dyes.
                      Andy
                      • befu
                        • Aug 2009
                        • 980
                        smoke
                        if you smoke, blowing a puff of smoke after a drag on a cig will also cure it. No idea why, but have seen others do it.
                        Brian
                        • ozoneone
                          • Mar 2010
                          • 31
                          http://www.offshoreelectrics.com/pro...prod=dh-pt-715
                          http://www.offshoreelectrics.com/pro...od=dh-topr1090
