vac-u-pickle!
  • thegreat1
    • Jul 2008
    • 249
    vac-u-pickle!
    hey guys i recently took delivery of a new pickle. i have 2 motors i could use just not sure which to go with. i have both an ammo 2600 and a fiegao 9l. i will be running 3/4s. so which would better suit this hull? ill snap some pics of the begining. so far all i have done is paint the hull.
    thegreat1
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7116
    what are your goals with this guy? race, sport, saw? speeds? batteries you wanna use? both sound border line 3S/4S, but with what props?
    "Look good doin' it"
    See the fleet
    • thegreat1
      • Jul 2008
      • 249
      i really don't know. i am totally new to hydros.
      goals: mostly sport, hopefully begin racing with it.
      batts:rhino 3s 3200's 2 paralleled to start 4s turnigy as many mah as will fit.
      props: ??? you tell me
      • Rumdog
        • 6453
        Swap out those motors for a ul-1 motor and run 4s. a x440/3 would be good. 4s is too hoy for those motors really.
        • thegreat1
          • Jul 2008
          • 249
          will either of these motors run ok on 3s? i already have both that is why i ask. if not then can i safely run the ul-1 motor with the xpower 100a esc? i ask because if i end up putting that motor in the pickle i will put the ammo or fiegao back into my rio ep with the hydra 120. that is where the ammo/ hydra setup resides right now.
          • Rumdog
            • 6453
            The X-power would be great with the ul-1 motor. Those motors would both work on 3s, but prop size would be more limited.
            • thegreat1
              • Jul 2008
              • 249
              needing bigger you mean or what?
