Whats wrong you dont like the KOS, sure is a sweet looking hull thow...im trying to find something right now to put on my skunk cat hatch like air rams think i can get some bathroom robe hangers from the hardware store that will look like them...they cost to much from like mhz...
Project Genesis!
________
BUY VOLCANO VAPORIZERLast edited by FighterCat57; 02-14-2011, 11:44 PM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Im a bit confused... I got my boat from HC, its states it has a 105A ESC. Where did you get yours from Alfa? Or is the 105 a typo and its a 125?
Genesis Offshore Brushless RC Twin Hull
A fiberglass hull perfectly finished and weighted as well as a powerful 105A brushless power system make this a seriously fast R/C boat.
Spec.
Length: 1045mm
Width: 245mm
Height: 115mm
Weight : 2.5kg
Motor: 36-74Size 2075kv Watercooled Brushless Inrunner
ESC: 105A watercooled
Drive system: 4mm
I still refuse to put it on 4S w/ all the "poofs" Ive heard about. I ran mine yesterday on an Etti 150 and some junk Reedy 20C lipos and ran 37mph on 4S. I know its got more I still cant get the set up right to keep it from bouncing. Also it seems the strut needs to go higher and its as high as it can go w/out lengthening the strut adjustment slot. So thats next. Its not winding out at all and hardly had a roost on 4s. Also came in pretty warm after about 3 minutes of run time. The 3S set up had a very small roost, but the boat bounced a lot so it varied from nothing to very tall. I will get it sorted out within the next couple days.Comment
The Tech Specs in the manual say 125a ESC. Looks exact same as the Apparition. I think it is a typo on the HK website.
4s on 2075kv is only about 30k, maybe smaller prop?
Have you tried lowering the strut? Seemed to do the trick on the Apparition.
________
Og kushLast edited by FighterCat57; 02-14-2011, 11:44 PM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Last edited by FighterCat57; 02-14-2011, 11:45 PM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Awesome, thanks. I will go check it out. Still kinda weary though. 4S on a 8Xl running a 442 is almost 120A. I think its just asking for smoke on a 125A controller. I will leave the stock ESC for 3S running boats. Im going to try out a 180A Turnigy. Maybe then I can turn the prop needed for this hull....
I think a 45 would push it very welll or even a tad larger for the size hull.
We run 8xls on 4s with 120s in monos no problem.If all of your wishes are granted, many of your dreams will be destroyed!Comment
________
Starcraft ReplaysLast edited by FighterCat57; 02-14-2011, 11:45 PM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
