Linkage question
  • speedsport
    • Mar 2010
    • 49
    Linkage question
    What are you all using for your linkage for steering? Is there any product I may be able to find at a hardware store I could use? The closest hobby store is 1 and a half hours away.
    Thanks
  • Jesse J
    Former scale FE racer
    • Aug 2008
    • 7198
    .078" piano wire, a vise and some good needle nose pliers. At the rudder end, the Dubro quick grip EZ connectors really are the pigs oink. You kinda do need a hobby shop or mail order access for the more elegant solutions.
    If you are not finding a solution, pm me your address I send you two (one for servo one for rudder).
    "Look good doin' it"
    See the fleet
    • OshkoshMono
      • Apr 2010
      • 207
      Hey Jesse, what do you think about the Stainless Steel Push Rod sets with clevis? I got a set, but not sure if I wana use them ????
      • m4a1usr
        Fast Electric Addict
        • 2032
        Thanks
        I like to use the 321 SS wire that I get from work. Its .092 and stiff as all get up. But I have used that LHS SS push rod stuff you mention and that can work. And there are so many options, Like this; http://www3.towerhobbies.com/cgi-bin...?&I=LXK099&P=0
        And this: http://www3.towerhobbies.com/cgi-bin...?&I=LXD876&P=0
        These are awesome too;http://www3.towerhobbies.com/cgi-bin...?&I=LXD906&P=0
        I prefer stainless 100% for my linkage's. No rust ever.
        Make or buy your self a "Z" bender. You only need one end to have adjustment. http://www.airfieldmodels.com/inform...nd_z-bends.htm
        John
        Change is the one Constant
        • Jesse J
          • Aug 2008
          • 7198
          why not? Like John's great set of links shows, there are many options. I don't care for the push rod sets cause I like to have adjustability at both ends. In the end its whatever makes you smile!
          See the fleet
          • j.m.
            • Jul 2008
            • 838
            The ball links and threaded rod will make some of the nicest linkages out there.
            Especially if you use the EZ connectors. Like the top links in this pic:
            They allow you to easily adjust the linkage with infinite precision.
            Jon
