Opinions on bottom of hull type octura water pickup??
  • OshkoshMono
    • Apr 2010
    • 207
    I ordered one of these as my 2nd pickup:Product ID: oct-ocsw
    Octura Streamlined Water Pickup
    I'm not sure I wana drill a hole in the bottom of the hull, but I figured this pickup would flow a good amount of water. I was thinking of mounting it about an inch or two forward of the transom on the left side (to maybe balance out the drag w/ the rudder being on the right?) and around an inch or two left of center hull. ??? Good idea? Or should I go with another style pickup?
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1679
    My opinion is you dont need a second water pickup. On my SV27 The temps stayed +-2 degrees with one pickup to two. On my twin cat I use one pickup for both esc's and motors. Temps are all under 120 degrees after a 4 minute run.
    JMHO
    • Chilli
      • Jan 2008
      • 3067
      I put on one my boat, did a couple runs and then took it off.
      Mike Chirillo
      www.capitolrcmodelboats.com
      • OshkoshMono
        • Apr 2010
        • 207
        Good to know. Thanks. I have a water jacket, water cooled motor mount and then the ESC. I was thining for one pickup, to run the water line to the esc first, then out to the motor mount, from the mount to the motor and then outlet...? Or would ESC (being most expensive) first, then motor, then mount be better??
        • tiqueman
          • Jul 2009
          • 5669
          I experimented with a few different thru hull pick ups that protruded past the bottom of the hull. All of them caused wierd characteristics in handling and ride attitude. Your best bet, if you feel you need another pick up is to use the aluminum flush mount thru hull steven sells, or just make them out of a piece of brass tubing. Theres a "how to" section on it in the 'tips and Info" section on the site.
          • OshkoshMono
            • Apr 2010
            • 207
            Ok, what about the kind that mount vertically to the transome? Any downside to those? I would think the drag is pretty minimal? Maybe I'll just stick with one pickup, I am just thinking the water cooled motor mount being added in will "slow the flow"....? Do you guys that have a water cooled mount just run one pickup for all three (esc, motor, and mount)? I did order a Y and a T fitting if those would be good to use in hose routing???
            • eboat
              • Aug 2007
              • 693
              You could also make a pick up like this
              If you use the T or Y in the plumbing the water will flow the easiest way and somethings might not get as much cooling as others
              • j.m.
                • Jul 2008
                • 838
                Prop wash pickups are best IMO because you don't get any drag on the bottom of the hull and you can use a thinner rudder blade with less drag.
                Jon
