some tech info needed on a new CAT project
  • omega
    • Mar 2010
    • 5
    Hello Guys
    I am new to electric boats (racing gasoline boats at moment). I have a 30 inch Aeromarine Cat Hull that I am setting up with a 6s Feibao 580 brushless motor, 180Amp Turnigy Marine ESC.
    The shaft will be 3/16 for a 1/8 prop.
    Can you guys suggest a good propeller diameter for this set up?
    Cheers
    Andre
  • ozzie-crawl
    • Sep 2008
    • 2865
    what hull and what kv motor
    • omega
      • Mar 2010
      • 5
      Katamaran from Aeromarine, 30 Inch long, Feibao 580 9L, 1,426 RPM per Volt... think is about 1450KV ?
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1679
        I dont think you would want to run a 1/8" prop. At least 3/16".
        • ozzie-crawl
          • Sep 2008
          • 2865
          okay i am taking it that its a mean machine, imo its a bit of over kill
          a 540 xl would be a better choice.or a neu motor on 4s
          other than that try a y537/3 prop from octura, you will want a .187 flex and 3/16 shaft
          • ozzie-crawl
            • Sep 2008
            • 2865
            read threw this lots of good info http://www.offshoreelectrics.com/for...read.php?t=751
            • omega
              • Mar 2010
              • 5
              thanks mate, been given the feibao as a suggestion from the guys at offshoreelecrtics.... you think drivable with a 6s 3850 TP packs? more for top end rather than competitive racing.... not much going on around here (Singapore) for electric... lots of gassers...
              • ozzie-crawl
                • Sep 2008
                • 2865
                if you havent brought the motor yet and want to go 6s a neu 1515 1.5y would be a very good setup.
                a decent 4s setup like a neu 1515 1y 2200kv on 4s 1p 5000 would be good as well.
                the feigao 580 is a heavier motor and less efficient than the neu
                the neu is $90 more expensive but well worth it.
                o.s.e also has the 1415 1.5y in stock and is only $50 more than the feigao this to would make a very nice 6s motor
                • omega
                  • Mar 2010
                  • 5
                  unfortunately i bought it motor the other day in hong kong... for a 100 USD so good price i guess? i get a feeling that i should have worked on a 4S set up... do you see any major set backs if i go with the big motor and 6S?
                  • ozzie-crawl
                    • Sep 2008
                    • 2865
                    the motor is fairly heavy but will produce more than enough power,i was just trying to give what i thought was better options.
                    that motor on 6s will still be a very strong setup,imo a little heavy but if pushing for high speed the extra weight may help.
                    one thing if your pushing for speed i would get on of these hatches, much easier to tape down and less likely to come of in a flip http://www.offshoreelectrics.com/pro...m-cowl&cat=123
                    • omega
                      • Mar 2010
                      • 5
                      thanks man, great advise... should be a fun boat... is a older aeromarine hull , shoe box design.... i will keep you posted here how this all ends up
                      • justintime2w8
                        • 260
                        Shoe box is great as long as you can keep the lid on the box:-)
                        www.radtekpowerboats.com
