HOTR twin build
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1598
    #301
    Cool man thanks!
    • egneg
      • 4670
      #302
      If you disregard the decimal and round up you are at 70!
      IMPBA 20481S D-12
      • blackcat26
        High Speed Junkie
        • Sep 2009
        • 1598
        #303
        No doubt! That's 70 in my book....
        • tiqueman
          • Jul 2009
          • 5669
          #304
          When my gps comes in and starts w/ a 7... then I will be
          Shes close, but not quite. I was outta town all day today so I hope to try for it tomorrow.
          • domwilson
            Moderator
            • 4408
            #305
            Taking in to account the accuracy of your gps unit, you probably did 70+ and your gps software just "averaged" it out. So take a bow.
            Government Moto:
            • tiqueman
              • Jul 2009
              • 5669
              #306
              Little mishap....
              So, in my quest for a tru 70 on the GPS, Ive had a small set back. I scuffed the hull w/ 400 grit to try and break the friction a bit. I only needed .2 mph for 70. So, I finaly got to run it this am. It runs A LOT different w/ a scuffed hull. 1st pass, I could tell it was running very very light... and then it blew over. it skipped, it danced, it cleared 100' while skipping once somewhere around 50 ft, then a short bounce and skip 10' from the end. It looked nasty. Once I got the boat in, which is a story in itself, I tried running it again but she just wants to blow over at about 3/4 throttle. Back home on the bench, a close once over immediately showed hull damage. The right side rear seam split a few inches and spider cracks are venturing out from the area. So far its all Ive found.
              Guess its back to the bench for a tear down and repar...
              Oh, and anyone have this happen... The GPS shut off. It also was loose after the episode. It powered back up and read 37.4 mph.... Id guess it was close to its top end when she went over. A lot closer to 70 than 37. Oh well. Repair time.
              • Jeff Wohlt
                • Jan 2008
                • 2716
                #307
                So then you would agree that scuffing the bottom improves top end and slickness?
                www.rcraceboat.com
                [email protected]
                • tiqueman
                  • Jul 2009
                  • 5669
                  #308
                  Without a doubt. I havent touched anything adjustment wise for 3 runs and the prior 2, the boat had a pefect ride attitude. I scuffed the hull and now its like my cog was moved back 3 inches. I guess the friction of the epoxy paint to the water was holding the bow down. Now that Ive broke that tension, she wants to blow over.
                  Unfortunatley, Ive made a build mistake. My batts are as far forward as they can go because they are up against the bulkhead. So Im going to try a stinger adjustment when its back in the water. If that doesnt work, I dunno.. I guess I will have to cut holes in the bulkhead for the batteries to slide into.
                  Jeff, did you get the decals I sent?
                  • ray schrauwen
                    • 9471
                    #309
                    Great reading sir, keep it up!
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      #310
                      My Forerunner did the same thing when it bounced around a bit. The battery tabs inside tend to let the cells get loose. I lightly soldered on to them increasing the thickness and tightening up the cells. Bending can easily snap those little tabs...
                      ________
                      Six
                      • tiqueman
                        • Jul 2009
                        • 5669
                        #311
                        So, I got it back together late this afternoon. Structurally shes repaired.. cosmetics is another story. I trimmed the stingers down a couple degrees. Probably dropped the tails about 1/8 of an inch. She ran real nice and tru, but I lost a couple miles per hour. Down to 67.5. It was close to dark so I didnt mess w/ anymore trim. Next I will try coming up just a little on the stingers to see if I can unload the props a little bit and still keep the nose down.
                        Oh and Im leaking water in now too. Havent found where its coming from but I went from having a bone dry boat to having around a tablespoon or two of water in each sponson. I think the seal on the rudder broke and its coming in from the bolts while stopped. I paused at the end of 5 or 6 passes for 10 seconds or so before I attempted to go flat out over its own wakes, which on this set up went very well, like they werent even there. So Id imagine while sitting still it was leaking in.
                        • HYDROJERRY
                          • Jan 2010
                          • 2503
                          #312
                          Glad you got her back together man,,,
                          • Rumdog
                            • 6453
                            #313
                            try an airdam in the tunnel to help keep it planted at high speed. It worked excellent on my sprintcat.
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3480
                              #314
                              What exactly is that? I've seen the spoiler type things on the hydros, but how would you accomplish that on the underside of the cat?
                              ________
                              Washington marijuana dispensaries
                              • tiqueman
                                • Jul 2009
                                • 5669
                                #315
                                Typically its mounted towards the rear of the tunnel (near the transom, bottom side) kinda like a wedge and helps keep the nose down at high spped. Ive seen some do a spoiler type at the top/ front of the tunnel as well, on the deck. Once I get it trimmed back out it will be fine. It was perfect before I scuffed the hull. If I cant get it right, I will just re-spray epoxy paint on the bottom and get it back to where it was.
