MHZ Cougar
  • cugino
    • Nov 2008
    • 136
    MHZ Cougar
    Hi,
    i have allmost finished my lagrest boat - MHZ Cougar 38".
    What prop and KV would you recomend for 9S1P LiPoly 5000mAh setup. I Have already bouhgt Feigao 580L 1051KV and Turnigy 120Amp max 12S regler.
    I would start with Octura X440. Do you thing that will work for speeds around 50mph? Can i reach 65 with larger prop?
    -= MHZ Shockwave - MHZ Micro Fountain - MHZ Cougar 2 - "Orange cat" =-
    http://olaf.webz.cz
  • Jesse J
    Former scale FE racer
    • Aug 2008
    • 7198
    Great looking boat. Is your battery configuration a single pack or several? (just curiosity).
    It looks like you will be spinning over 30K rpms with that set up. I would go lower kv myself with a bit bigger prop, but I will be watching to see what people with experience say (I have none).
    "Look good doin' it"
    See the fleet
    • cugino
      • Nov 2008
      • 136
      I ran 3 single pack. I use 3S packs in all other RC models.
      I thing, my combination 9S LiPoly + 1050KV i can consider like 4-5S and 2100KV motor, right? What prop this combination takes for sport? What poprs are good for hull of this size?
      http://olaf.webz.cz
      • DISAR
        • Aug 2007
        • 1072
        440 would be quite small I think, cavitating a lot. Depending on your strut depth also. However I think that the problem is not the props but the motor. Try also a 442 but I think the max. you can go is 445. Always check the motor temperatures after 1 min run in the first tests.
        I don't think that you can make this boat run 50 mph with the feigao 580, maybe 40? Tell us the results...
        http://www.rcfastboats.com/
        • cugino
          • Nov 2008
          • 136
          OK, i let know results soon.
          What setup would you recommend for sport boating ,60s ? I this possible with 6S 5800mAh LiPo?
          http://olaf.webz.cz
          • DISAR
            • Aug 2007
            • 1072
            Maybe a NEU 1521 1y, or a 1527 1y. What is the weight of the boat?
            For 60 mph you would need also a "strong" esc.
            • Eodman
              • Sep 2007
              • 1253
              Great looking Boat --- almost makes me think of trying a mono!!!! On second thought No No No hell NO
              We did it with a Bang!
              Cats Are Where It's At!
              • cugino
                • Nov 2008
                • 136
                There is little more of my fleet :-)
                http://olaf.webz.cz
                • DISAR
                  • Aug 2007
                  • 1072
                  Nice boats, the Cougar certainly is very attractive! So what have you come up with?
                  • cugino
                    • Nov 2008
                    • 136
                    I little more of cougar
                    Cougar overal weigh is almost 3kgs without LiPos i wait for, probably hang at customs house.
                    There are more pics of boats. Little repairs insight and little of outside.
                    http://olaf.webz.cz
                    • DISAR
                      • Aug 2007
                      • 1072
                      Nice job, I see all MHZ hardware right? This is the trimax singer? What do you think of it?
                      I am watching these monos from MHZ and mmm thinking of one....
                      • cugino
                        • Nov 2008
                        • 136
                        I like MHZ monos, i have only ones. Micro mono GMC Fountain is very cute. My wife drives micros.
                        I like curves of Fountain boats. They looks good and drives too, especialy ShockWave. Shocwave is quite small, but very sharp. With 6S LiPol and Hacker B50S and CNC 34mm prop, is fast enough and corners like on rails.
                        Yes, Cougar is equiped with MHZ hardware. Trimax looks good and works even better - "3D" adjustment is very useful.
                        There is picture of Cougars back..
                        http://olaf.webz.cz
                        • cugino
                          • Nov 2008
                          • 136
                          Cougar
                          Hi there,
                          i got close to finish. Almost everything is in place.
                          I look forward to do some test on the pond near by..... but there is still ice.
                          So, there is at least photo of inside.
                          http://olaf.webz.cz
                          • mappo
                            • Feb 2010
                            • 487
                            cougar
                            Hey, what a great Boat! that deserves a better motor! Try 1521/1y 0r 1527/1y and start with a x452 and check temps. with those 580l try a x642 and work your way up while checking temps.you may want to try a different Esc, like
                            MGM 12545-3 E-SERIES. or Z SERIES.. what model Mhz rudder are you using?? i like. hey when you are setup could you post some video? .:rockon2
                            Do you know what the biggest problem with the world is?
                            That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
                            • cugino
                              • Nov 2008
                              • 136
                              With 9SA123 batteries it weights about 3250g. It isnt so much, but 9S A123 isnt not enough power for this boat.
                              I would try 8S LiPoly Turnigy NanoTech 4000mAh 45-90C wiht Prather 225.
                              I post video ASAP.
                              http://olaf.webz.cz
