A little background on the Wake Maker mono. This is a hull I designed about 5 years ago to run in N1/N2 mono and 19T spec classes. The prototype measured 21 1/4" long by 7 1/4" wide. At that time this seemed to be the standard size for many existing hulls on the market. I built the first prototype and ran it for 3 years in N1 and 19T spec with good results. During this time brushless motors were getting more popular and I realized this hull probably would be too small for the "modified" classes so I made some changes to the design and increased the dimensions of the hull to 23" long by 7 3/4" wide. I had 3 prototypes cut with the intentions at the time of selling this hull in kit form if it proved to be a good runner. So I built one of the kits and sent it to Paul Pachmayer for testing. Reports came back good. With a few adjustments to the patterns I was ready to have kits cut for sale. However by this time Lipos started getting a lot of attention and it was soon evident that the smaller hulls of that time were going to be getting replaced with larger hulls. I decided to hold off on production of the kit and actually ended up taking a couple years off from boating altogether. I have had the other two prototype kits sitting around collecting dust for the last 3 years and finally decided to blow the dust off and build one of them. So I figured I would post the build here for others to see.
These first pictures are of the smaller original prototype that I use to race. As you can see from the inside layout there was enough room for all the gear with just enough room for moving things around. There is a turn fin on the boat but you can't see it in these pictures. It was mounted flush to the right side freeboard at 90 degrees to the deadrise. I took inspiration from Ed Hugheys monos, this is how he did it.
