Best Whiplash Lipo Location
I'm working on mine now. two 2S Hyperion 5500's up front. They are HEAVY. Still need some nose weight! It will be even worse with my Flighpower 5000's....much lighter. DANG! Boat is built and closed up. too late for weight in the sponsons.Mini Cat Racing USA
Yep. It is hard to get the forward weight on this hull. You could drill a small hole in the bottom of the sponson tips and add BBs and epoxy. Then seal the hole up.Comment
I may have to. I added 3.5 oz. in the front of the tub today and still enough. The other alternative is to move my servo way forward.
Mini Cat Racing USA
My 2 cents is get the cells as far forward as possible. Anything less and the butt end will drag around the pond. My cells are now way up into the nose of the hull with the motor right behind them and it is the best running hydro I have ever owned. It will run wide open all the way around the pond and will turn like it is on rails at 60mph. My Whip was built a little heavy to withstand some abuse so it did run wet at first but once I figured out how to properly load a 1515 1Y on 4s it became a water rocket.Team Liquid DashComment
Whiplash 20 Lipo
Kit just arrived and build is starting. My basics are Neu 1515 1Y on 4s. What prop are you using to properly load the motor and where did you locate the 2s2p or 4s1p cells?My 2 cents is get the cells as far forward as possible. Anything less and the butt end will drag around the pond. My cells are now way up into the nose of the hull with the motor right behind them and it is the best running hydro I have ever owned. It will run wide open all the way around the pond and will turn like it is on rails at 60mph. My Whip was built a little heavy to withstand some abuse so it did run wet at first but once I figured out how to properly load a 1515 1Y on 4s it became a water rocket.
Thanks for the info:
jesfloridaComment
This is where my cells are, and the motor is right behind them.Attached FilesLast edited by Raydee; 12-19-2009, 08:38 AM.Team Liquid DashComment
