I just got the laser cut parts today for a 30" catamaran. It is basically a scaled up version of the Shockerman plans that I got from JesseJ. The original plans are for a 26" boat and I scaled them up for a 30" boat.
The parts laser cut by Alex Guzman, who actually did all of the work in scaling them up and laying it all out. (http://a-mmodels.com) Alex did exceptional work and gets my highest recommendation if you are looking to get some parts cut.
The original plans call for building the boat from balsa... but I am biased against balsa in boats at this point, so I had the parts cut from 1/8" light plywood. The plan will be to add some pink foam in the front sponson areas and sheet the boat in 1/32" plywood.
I did a quick test fit of the parts ... and they are perfect.
I am excited. This should be fun. The plan is to use a UL-1 motor and ESC, OSE inline drive hardware, 4S Lipo and race the boat in the spec Offshore class next season.
Probably to be built with 1/4" plywood.
