A lot to be done before maiden voyage due (hopefully) on 2010 summer. Lakes are on ice the next 6 months...
So I ll be bothering you during the whole winter.
I got the mhz drives for mystic and now I am wondering how to attach flexshaft to prop shaft. It says on the MHZ site that this drive has "universal 2mm bore". So the hole in the end of propshaft is 2mm. There is no way it could be largened to 4,7mm which was the mhz suggestion for flexshaft. There is just not enough material... for example the propshaft it self is that 4,75mm... The drives themselfs are from mhz catalogue and sized "for 44,8" hull"
"This drive has a propshaft (shaft for props) of 3/16`` (4,75mm)
The milling for the propshaft (flex or steal) is universal 2mm and able to get enlarged up to 3,2 mm or 4,7mm " //mhz-powerboats.com
I will ask MHZ, but before some questions to be able to ask right questions:
- could this be done with coupler from 2mm hole to 4,7 to attach to flex shaft? (couldnt find any suitable)
- have somebody experience with mhz drives and similar situation?
- drilling 2mm to 4,7mm with these tolerances is diffucult job for professional and for me beeing incompetent in all walks of life - impossible
So I ll be bothering you during the whole winter.I got the mhz drives for mystic and now I am wondering how to attach flexshaft to prop shaft. It says on the MHZ site that this drive has "universal 2mm bore". So the hole in the end of propshaft is 2mm. There is no way it could be largened to 4,7mm which was the mhz suggestion for flexshaft. There is just not enough material... for example the propshaft it self is that 4,75mm... The drives themselfs are from mhz catalogue and sized "for 44,8" hull"
