OK, I have had my 24" mono running a few times, but I never put strakes on the hull. Has a built spray rail, but the strakes are to be added. I have several strakes now that need to be glued onto the hull, in the pictures below they are just laying there. Still need to have the edges sanded as they are raw bondo fresh out of the mold.
My own 24" mono, hardware from a 25" prince mono hull, Turnigy 3650-2300 motor, 35 amp HKSS speed control, and two 3s-1800 packs in parrallel. 28mm plastic prop from OSE, average amp draw is around 22 amps (5 minutes on one pack). Motor is rated at 400 watts, which is 36 amps on 3s. (need an eagle tree from Santa!) RTR weight is right at 2.5 pounds with both batteries.
It seems to run pretty wet right now, think the batteries need to move back, but the strakes will also help to dry the hull up some. It is like driving a drifter as it really slides thorught the corners. The second battery helps as it adds some weight. Haven't tried a turn fin yet, will add that later.
So, where should I put the strakes? I was looking at two per side, evenly spaced. The outer one starting at the transom, the inner one starting about 3 inches forward of the transom. Anyone have any input? Three strakes, other crazy ideas?
You know, it was a really pretty looking hull with the kevlar and carbon mat, but I put some spray foam inside it and now the bow area looks funky. I constantly amaze myself with my own stupidity
