i was hopeing that someone could help me with a few problems i am having with wireing lipo packs in parallel. i am not new to FE or electronics so i understand the theory good. here are the set-up's and 2 problems i am having:
1) this is a 2s boat, NEU 1512 1d, cc 240, 2 x 2s-5000mah 30c in parallel. one of the packs (the same one every time) uses aprox 200 mah more than the other. i use a y made out of 12 guage wire with 5.5mm connectors to put the packs in parallel. WHY IS ONE PACK USING MORE?
2) neu 1515 1y, cc240, 2 x 4s-5000mah 30c in parallel. this is the same as above only on this boat one of the batteries was fully charged and the other was 3000mah used. i use 10 guage with 5.5mm.
i was wondering if it could be that there is too much solder on one side of the connectors or is that something that would not make a difference? the wire legnths are the same on both packs and i am getting solid continuity. i guess the next thing i should check is flipping the Y connector and see if the pack that is low changes. i havent paid any attention to that yet.
if anyone has had a similar problem or can shed some light on what is going on please help me... thanks
