20230829_163730.jpgF1h2o Italian job
Thanks Paul you explained it well. Made a carrier cum work station for the f1 all ready now for tomorrow's meeting. She is heavy and will sit low in the water, but should rise up when moving.
The rear battery has leap froged the front battery into a forward position, this brings the cg somewhere near. I could try the jet outboard on this boat to reduce weight at the back, and there is always the option to build a shorter/lighter prop outboard.
Getting all the wires and cowl in place is tricky , done by having the rear end loose at the same time.
