Kyosho Majesty 800S
  • Stillwet
    • Jul 2018
    • 241
    #46
    double post Boo!
    • Stillwet
      • Jul 2018
      • 241
      #47
      Just started JDS stainless steel tubing rails,
      this size is .082/2014 this tubing is one of the sizes i use for my 24th scale Drag Slot chassis
      there are a few more still to do.
      the stairs going up to the upper deck
      i used cork gasket material for treads, and .050/2017 for hand rails.
        • 7673
        #48
        Holy crap, that is gonna look good
        • Stillwet
          • Jul 2018
          • 241
          #49
          i want to take more pictures but it's all too raw, i don't mind taken the time to do it, it's just like a tile job before grout, it's almost there but the lighting is going to take some time, as far as under water lighting goes i'll just tow a flashlight behind
          • Stillwet
            • Jul 2018
            • 241
            #50
            i used two of these pens chrome tips for the housings
            2mm button head screws
            • Stillwet
              • Jul 2018
              • 241
              #51
              the lower deck has a gas grill so it had to have a supply, and it has a hose, but not until it's glued in place.
              A 1/32 scale figure.
              an aluminum pull tab lid from a peanut container.
              Red paper clip.
              a cap from some left over hardware from a remodel job. (i collect bits and pieces) for scratch building.
              a valve stem core.
              train wheels from my N gauge train boxcar parts.
              whats nice you can make this any size just like my Milwaukee 1:1 hand truck.
              there's quite a bit more to come. i'm gearing up for my Tamiya Grand Hauler to tow this boat around and my lunch.
              • Mike W
                • May 2018
                • 348
                #52
                A real veneer and Sharpie the black lines?
                Otto RC Marine
                • Stillwet
                  • Jul 2018
                  • 241
                  #53
                  are you talking about the mahogany decking? i had completed the upper and lower deck already, and yes i wish the lines were more apparent but it still looks good, (if that is what you meant) is a good tip. i wanted to do a different wood color in between but it would had been more time when i was into it and had still a lot of lil' details left, i keep a ledger and log every thing that comes to mind and or read and see, ideas are every where. i'm posting the decks tomorrow or Friday and then finish the electrics and hardware. i still need to use rubbing compound & wax the boat to get it to shine more. Thanx again for the Sharpie idea, hopefully i'll get to experiment with it on another project.
                  i do use Sharpies often.
                  • Alfa Spirit
                    • 2131
                    #54
                    Very nice job Stillwet, I like the Graupner Portofino but it' s not easy to find one
                    • Stillwet
                      • Jul 2018
                      • 241
                      #55
                      Thank you Alpha Spirit.
                      Are you just starting your build? that boat is very nice indeed, i wanted to do a Dumas kit again but stumbled onto the 800's.
                      are you doing a build log here for your Portofino?
                      i would like to follow your build if you do.
                      i just started lighting last night, not many but still a chore.
                      • Stillwet
                        • Jul 2018
                        • 241
                        #56
                        Lower Deck;
                        Hand Truck with Propane Bottle (see Thread #51), blue hose i've had so long i do not remember where it came from, BBQ Grill is a Fuel Cell (with M2 screw/nut installed through the deck) as stand and Batteries from a left over model kit, Spatula is an aluminum piece and part of a stainless steel hoop earring. (notice the the dry rub and spice containers, the brown and green cans), Glass Beer Keg is a glass bead, gold barrel clasp, mini "T" Pin lever (you can't see it from this view) blue anodized paper clip and clear tubing, Fire Extinguisher painted Red K'nex part with Aluminum Wire and Black Silicone wire insulation.
                        Aluminum door trim ripped from a shower door jamb, Diamond Plate and Speaker Grilles left over from my Axial SCX10 Rubicon Jeep Build, Vinyl Aluminum style sheeting, and Holographic Crystal tape.
                        i'll post the Fly Bridge soon.
                        Hull is buffed and polished and ready for Hardware, Running Gear and Electronics.
                        Door Handle "T" Pin, Black/White Rope left over from Kyosho Seawind Build (sails rigging), Brown Rope some small cord i found mixed in with some beading, another Propane Bottle in a stand made from an Epoxy two part container tube(s) top, and Warning Labels from my Train's supplies.
                        • Stillwet
                          • Jul 2018
                          • 241
                          #57
                          Fly Bridge
                          well this was a hull lotta fun
                          i do not know how the below Attached file popped up.
                          • Stillwet
                            • Jul 2018
                            • 241
                            #58
                            Fly Bye Bridge, Part Deux
                            now onto the ESC and re-calibrate the servo and the transom hardware.
                            the lights work great got them to function on "D" with my TX.
                            i'll post when completed. a lil' hassle but hey it had to be done.
                            • Stillwet
                              • Jul 2018
                              • 241
                              #59
                              Lights, Camera, and still needs water
                              • Stillwet
                                • Jul 2018
                                • 241
                                #60
                                Prop, front hatch, some zip ties, re-wax and then flash pictures will we see the Majesty in color.
                                i'm making a variety of fenders from different pens.
                                This just beckons for me to start a Galleon or Clipper ship.
