Skippies and Kiwis
  • drwayne
    • May 2008
    • 2981
    #3451
    Re: spektrum assist plz.
    [Quote Originally Posted by drwayne]
    http://forums.offshoreelectrics.com/...344#post336344
    issues with Rx activation too slow for SF esc when using bec
    thanks
    DrWayne
    Adelaide
    Australia
    [/quote]
    I got lucky finding this message. I hardly ever visit OSE any more due to support on RCG for the DX8. Please e-mail me andy@[deleted] or andy@[deleted] in the future.
    Spektrum receivers do not send any signal to the ESC until it connects to the transmitter (ie, finds the frequency(ies) in use by the tx). This is a failsafe operation, preventing it from accidentally arming an ESC when it should not be armed. We do this on ALL our receivers (Air, Marine, and Surface), and have since the beginning and it will not be changed since it is a primary safety functionality.
    Andy
    Spektrum Development Team
    I have made comment to hasten the recognition and activation would perhaps solve this dilemma.
    Waiting for return.
    • drwayne
      • May 2008
      • 2981
      #3452
      Wayne, if the bec is removed may that resolve this issue with this ESC.
      Douggie
      ???? .. not with Spektrum, according to millzee.
      Spektrum with Rx pack to a Sf240HV is puzzling.. as that bypasses the Spektrum recognition and activation delay issues....but he still faces this <100% problem.
      W
      • drwayne
        • May 2008
        • 2981
        #3453
        Originally posted by millzee
        I am using the sf240 in a df35 pirate(single), the esc has no internal bec, I've used a rx pack from day 1. I too have the throttle travel up around the 150 mark and it's helped the issue.
        Originally posted by Xzessperated
        millzee, what speed are you getting out of that pirate?
        Maritimo twin
        I ran Futaba 3Pk Faast to a Rx603fs with NO Rx pack .. feeding twin SF120
        No probs.
        Sprintcat40 twin
        I run Futaba 3Pk Faast to a Rx603fs with Rx pack .. feeding twin SF240HV
        No probs.
        Guess Im just lucky ....
        • Xzessperated
          • Apr 2008
          • 3060
          #3454
          Originally posted by drwayne
          Maritimo twin
          No probs.
          Sprintcat40 twin
          No probs.
          I can live with the problem. I love my Spektrum.
          Thanks to you and Andy for all the trouble you went to.
          Several boats in various stages of destruction
          • drwayne
            • May 2008
            • 2981
            #3455
            From Andy:
            Connect the rx as you normally would. This would cause the delay to occur. Now, power it down, then apply power again. This will cause the rx to immediately check the last channel(s) first, causing it to immediately find the transmitter.
            Andy
            • Flying Scotsman
              Fast Electric Adict!
              • Jun 2007
              • 5190
              #3456
              I am still confused...a part of old age?...but is this a specific ESC problem?
              Douggie
              • Xzessperated
                • Apr 2008
                • 3060
                #3457
                Douggie
                The way I see it, it is a Spektrum radio problem. Andy Kunz is telling us it is built in as part of the fail safe so motors do not fire up accidentally. It could be a pain in the a$$ to a greenhorn or someone that did not have access to a forum such as this one. Steven obviously has never had the problem. I have only had it twice. Anyway now we have 3 workarounds for the issue and few people seem to experience it. I like the idea that it is built in and I like Andy's workaround. I will not be moving away from Spektrum in a hurry as I find them easy to program and the telemetry and the "drop them in your beer" receivers are two great +'s IMO.
                Edited in...
                To be truthful, I always try some Throttle Travel on any of my setups just to see if I can squeeze another mph out of them. This is always done carefully so as to make sure the motors shut down with zero throttle. I never presume the radio has found full throttle. Sometimes I get a pleasant surprise.
                • drwayne
                  • May 2008
                  • 2981
                  #3458
                  just for you interest ( and envy )
                  sprintcat 40
                  props are just for show..
                  • Xzessperated
                    • Apr 2008
                    • 3060
                    #3459
                    What are the silicone hoses going to the stingers for? Perhaps the way you are going to apply the Wet Stuff to lube her up!!!
                    The pictures show just how bad the gel coat finish is on that hull.
                    Where are AM hulls made?
                    Even DF clone hulls have a good gel coat. The quality control guy must have been at the doctors the day they packed that hull.
                    • drwayne
                      • May 2008
                      • 2981
                      #3460
                      silly cone tubes feed light oil into cavity between stub shaft and brass outer guide ( ~20mm) to lube roller bearings
                      [][][][]==I=====8
                      • Xzessperated
                        • Apr 2008
                        • 3060
                        #3461
                        [][][][]==I=====8
                        Ahaa. Seems like a good idea. I am a pussy virgin as you know.
                        • Xzessperated
                          • Apr 2008
                          • 3060
                          #3462
                          All I can say after just one test of your old Maritimo and a check of your workmanship on that hull is that this hull is gunna (I know you love bad spelling and slang Douggie) fly and be as strong as a brick out house.
                          sprintcat 40
                          • drwayne
                            • May 2008
                            • 2981
                            #3463
                            Monos have these things too ..I know a top hydro nitro fella has a drain from tuned pipe that feeds to strut ( dunno if it works ) which looks impressive .
                            i admit pussies are the most fun yet.. two screws at once fighting the other.. counter rotation twisting your ass one way then the other.. great thrill when they're all hooked up screaming wide open .. all under your control.. ... .. yummy stuff.
                            • millzee
                              Ozzie Bloke
                              • Nov 2010
                              • 1092
                              #3464
                              sprintcat 40
                              [ATTACH=CONFIG]54843[/ATTACH]
                              [ATTACH=CONFIG]54842[/ATTACH]
                              Looking real good, can't wait to see a vid, better yet, bring that thing over my way, I've got flat water almost 95% of the time and a few cabins
                              "Gimmy Toyz for FUN"
                              • Xzessperated
                                • Apr 2008
                                • 3060
                                #3465
                                Wait up, I am on the way. Flat water 95% of the time. Man you live in heaven
