Skippies and Kiwis
careful who you call a retard..
Castle were converting air esc to marine applets.. thus their pitiful prog options.
All the name brand top end esc offer mapped timing rates . MGM, Shulze, HiFei :) , and now the CC-ICE ..
Cars and boats are streets apart ... !
'boost technology' sounded like a soda pop slogan ..
WI was more referring to Dougie
You know I still love you all, but not in that way.
It's weird how far ahead rc cars are, even down to the mechinical timing on the motors with ability to add timing in 2 degrees increments up to 40 degrees on some brands of motors. Btw could you run a car motor in mairne? Or a car esc?returning to boats after a big breakComment
I guess it is not a secret that Dr W sold me a pussy, namely a H & M Maritimo pussy. I took it to the lake this morning for the first time and came home with a big smile on my face. I did not get full throttle because the Swordfish 120 esc's do not pick up full throttle on a Spektrum radio correctly. To overcome that problem I was increasing the throttle travel each time I sent the boat out. Dr W explained to me how to fix the problem in a better way.
Setup is 2 x Castle 1512 motors, 2 x Swordfish 120 esc's, 6s1p lipo and 2 X442 counter rotating props. Speed was 101 kph or 62.75 mph and climbing as I increased the throttle travel. Dr W has seen 88 mph with this boat so I am expecting big things.
5898803945_75d55068db_b.jpg5898805633_0d987a8fa5_b.jpg5899368744_70b32e6da3_b.jpg5899364966_3d932bb15a_b.jpg5899362686_f8b7f4494f_b.jpgSeveral boats in various stages of destructionComment
where's the waterproofing white tape back right corner covering the engine mount access hole ?
umm, if you missed that arse hole on the rear, did you seal the antenna hole near the plugs ?
looking at orientation the gps Vs dukfuka decal, .. the gps is facing backwards !
101kmh backwards is impressive, m8 !
WLast edited by drwayne; 07-03-2011, 10:16 PM.Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
WNah I had to tighten the motor mount bolts on that side. I used OSE hatch tape to cover the hole. Antenna hole sealed. Boat sat in the water for more than 30 minutes (waiting for the wind to blow it across the lake after the esc leads came off the receiver) and was as dry as Andy's whisky bottle on a Saturday morning.
Last edited by Xzessperated; 07-03-2011, 10:43 PM.Several boats in various stages of destructionComment
A white pussy are you marsupials all mad and can not paint...mind you, not too shabby speed.
DouggieComment
Can not paint... wrong. This will be a future job although it will not be as nice as a Canadian HPR 130 (+ or - 5) that had it's pictures on OSE today. That is one beautiful boat.
URL to the HPR 135 edited in
http://forums.offshoreelectrics.com/...710#post326710Several boats in various stages of destructionComment
[ATTACH=CONFIG]54737[/ATTACH][ATTACH=CONFIG]54738[/ATTACH][ATTACH=CONFIG]54739[/ATTACH][ATTACH=CONFIG]54740[/ATTACH][ATTACH=CONFIG]54741[/ATTACH]Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
All use SF esc with bec.
This maritimo had no problems with 3PK Faast.
Perhaps andykunz could shed some ideas ?
[ just PMd him ]
edited: not sure delay before spektrum Rx sends data to client/servo after powerup+bind , but SF scripts have 1.5 sec delay between powerup and Th high is set ... and tones sound
shortcut is to hold Tx Th at 75% when calibrating esc.. allows for 100+% for wot.
WLast edited by drwayne; 07-04-2011, 10:14 AM.Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
Douggie, I will try using an external pack sometime.
Doc W, were larry and millzee also using twin motors, twin esc's?Several boats in various stages of destructionComment
I am using the sf240 in a df35 pirate(single), the esc has no internal bec, I've used a rx pack from day 1. I too have the throttle travel up around the 150 mark and it's helped the issue.Comment
I'm still playing with the tuning but so Far the fastest I remember seeing on the gps is 98kph, it's got more in it, I just need to learn how to get it out. It'll run at mostly full throttle input for about 5-6minutes b4 the lvc kicks in and temps stay within the safety limitsComment
