My budget solar/electric full size boat project.
  • Turbo Dan-O
    • Feb 2011
    • 292
    Something I've been playing with for a little while. Thought you guys might get a kick out of it. I started playing with a small paddle boat and added a trolling motor and a couple of solar panels to it. It really worked out well, but the small size and horrible hull shape became a brick wall. I wanted to take this project to the next level so I picked up a 1976 Newport 17' sailboat. Now we're talking! We now have an RC rescue boat that can carry ALL of our gear, charge batteries, take us to islands/calm water and you can even sleep on it! All built out of simple, low budget parts. Here's some pictures of our new float "Current Situation".
    Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!
  • fweasel
    master of some
    • Jul 2016
    • 4311
    Best... Recovery... Boat... Ever.
    Vac-U-Tug Jr (13mph)
    • larryrose11
      • Jun 2010
      • 761
      what is the power setup in there now?
      What batteries and Solar equipment?
      • Turbo Dan-O
        • Feb 2011
        • 292
        Here's the current setup. Not breaking any speed records, but it's efficient and get us where we want to go even in a little wind and current.
        Minn Kota 30lb that has been gutted and redone with a 40 amp PWM and 10 awg wire. Using APC model airplane props and a spinner. Still playing with different ones, but the 11x6 seems to be a good balance between speed and efficiency.
        Solar power is two 120 watt flexible panels in parallel and a 20 amp MPPT controller.
        Batteries are two 24 series lead acid deep cycles in parallel. Tucked under the seats.
