3 ESC cables vs 6 motor connectors
  • SerraAvatar
    • Aug 2020
    • 2
    Hi there,
    I bought Lehner 3060 motor and TMM 25035-3s ESC combo. The motor has 6 connectors but the ESC only has 3 wires... I was wondering if anyone could shed some light as to how the motor should be connected please?
    Thank you very much for reading!
  • meangenesracing
    • Jun 2012
    • 1163
    Does that esc have watercooling? Looks to small for that motor
    • NativePaul
      Greased Weasel
      • 2761
      It is up to you how to wire it. With 6 wires coming out of the motor you can choose to wire it up in D (triangle) format for high KV, or Y (star) format for a KV that is 1.732 x lower.
      Here is the Lehner manual showing how to wire each format.
      • SerraAvatar
        • Aug 2020
        • 2
        Thank you NativePaul for the input :)
        Regardless of whether it's the D or Y format, there are 6 wires form the motor. Am I correct in say that I could join each pair (1,2 and 3,4...etc) together (as indicated in the attached picture) to make this work for a 3-wire ESC? Thank you very much.Lehner_Connector.jpg
        • NativePaul
          Greased Weasel
          • 2761
          Yes.
