It's winter in maine!! Check out the Kyosho blizzard first person view! Give it a like----> http://youtu.be/lhGb1OadEl4
video of Kyosho blizzard... WINTER IN MAINE 2014
Tags: None
Very Cool, I have the older version which has only ONE SINGLE motor and turning is accomplished by two disc brakes that provide differential speed on the treads, the newer version is better with two independent motors much like Tamiya RC Tanks.
That old version had a mechanical speed control, the whole set up is rather jerky, replaced with an ESC and also a crawler motor which provided slower speed but much better power curve for the disc brakes in order to have smooth turning capability.Too many boats, not enough time...
Wow, may be you dialed it in better than I, it's ok now, another question, I tried to find a better DRIVE CHAIN, the standard issue is like a woman's necklace.
Would be great if there is a miniature bike chain type up grade.
I haven't seen anything like that.. I do know you can tighten the ones that come on it.Good times had by all!Comment
